Other parts to change w/ cam
Originally Posted by Snake Eater
The stock springs are good to .550 lift, so if this cam only has like .525-530 lift i personaly wouldnt bother. But thats just me.
If that's the case, tdrumm can get off real cheap (relatively of course). Cam, gasket kit, fluids, and tune. I'd definitely do some research on the springs though.
Originally Posted by TheLadiesMan
what rpms could you run stock springs out to?
From what a GM performance guy told me they are good to .550. They are the same in the F-body. And the 98-00 came with .500 lift. Also you could add some 1.85 rockers without changing sprinds, which brings it up to .544 i believe.
As far as changing gaskets, WHY? They are ALL o-rings and can be reused. I had 61k miles on my engine when i did my swap and its never leaked a bit.
Check it out, $36.95 plus s&h. http://www.sdpc2000.com/catalog/2721...asket-Kits.htm
Why pay over $400 for a cam and then skimp on the gaskets...just doesn't make sense to me. But hey, opinions vary. I'd rather drive my truck than fix it twice.
Thanks for the replies guys, since it looks like my chain, oil pump, and pushrods are OK, I'll be doing just cam and springs, and like budhayes3 said, for $37 bucks the gaskets and bolts are too cheap not to replace. Hopefully I'll be able to pull together some more money to do an ASP pulley too since I'll have it off to do teh swap.
V-seriesTech
Jul 28, 2015 12:31 PM
Suburban2500
Jul 19, 2015 04:50 PM
