ORY or X pipe?
Old Jun 17, 2005 | 01:08 PM
pacebria's Avatar
Default ORY or X pipe?
I am getting some LT headers on my 2005 HD and was wondering if I would be better off with the ORY or a X pipe I will be doing a custom exhaust so I can do either one with bullet mufflers. Thanks For any help
Old Jun 17, 2005 | 01:19 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Xpipe and good choice on mufflers I will be putting mine back on and getting my cats cut off.
Old Jun 17, 2005 | 01:54 PM
Last Call's Avatar
TOTM: January 2007
The ORY pipe is just 2 smaller diameter pipes that merge to from 1 pipe larger pipe that goes back your muffler. ORY usually means that there are no cats on the y pipe.
An x-pipe is used to balance out exhaust pulses. You need true duals to have an x-pipe that is functional. The best place for an x-pipe is close to where the 2 pipes meet. Usually on the passenger side underneath the cab.
Since you have a 2500HD with a 6.0, you probably dont have a y-pipe. You have 2 seperate pipes that run parallel down the length of the passasenger side of the truck and merge after the muffler.
A ORY pipe will probably give you more power than an x-pipe since cats are a restriction. The more power you make, the more power you will lose through your cats.
Old Jun 19, 2005 | 08:44 PM
pacebria's Avatar
I am going to do away with the cats anyway I just wondered which made more power X or Y without cats and LTs
Old Jun 19, 2005 | 09:35 PM
02sierraz71_5.3's Avatar
true duals with an x flow better
Velocity1
Oct 12, 2015 10:39 PM
03sierraslt
14
Oct 9, 2015 05:53 AM
JordanH
Oct 3, 2015 03:59 PM
BlownHD
Oct 3, 2015 12:24 PM
JordanH
Sep 12, 2015 12:02 AM
