Opinions on STS kit?
Old Nov 12, 2006 | 02:45 AM
Originally Posted by Wilde Racing
I don't know, there sure is alot of nicely bent coated Pipe with a sts kit.
I'm kinda glad not everyone likes the sts kit. I like being different (and fast).....Now go buy a front mound and start cracking manifolds. lol
Depends on the kit. Most "kits" have fixed these issues.
Jim
Old Nov 13, 2006 | 09:02 PM
I kind of agree. I can fab and build my own kit, I just cant find anyone who will give me a P/N or a way to get one of those damn oil pumps. I did my own kit on my Blazer and it only took 6 hours start to finnish, all fab and everything. Thing is the turbo could be mounted high enough to gravity drain and didnt need a oil return pump.
I would like to boost my Yukon, but I need one of those stupid pumps.
Oh, Banks is making a kit identical to STS for the Vettes and Fbodys, but I bet there ALOT more than STS.
Old Nov 13, 2006 | 09:06 PM
8ALTNG's Avatar
I think that STS kits are worth the money, but they have their limit. My truck wont hold boost on the dyno with the kit and I know a few other cars that wouldnt hold boost with the STS, but then changed to a front mount and now they will hold the boost.
Also rain is a big issue with the kit on a lowered truck.
They do make power.....over 550rwhp out of a 4.8 liter....
On a side note I do know of a nice one for sale. FMIC, 67mm turbo, bov, controller, and it makes TONS of power
Old Nov 20, 2006 | 10:04 AM
slowec's Avatar
I gave 2300 for a used kit
250 injectors
250 tune
110 fuel pump
280 gauges
150 used lc1
3340.00
You can't hardly buy a used maggie for that and you'll still need tune,gauges, fuel pump and lc1!
In short, its WORTH IT!!! You can't knock the grin off my face
Old Nov 20, 2006 | 10:24 AM
spitfire2332's Avatar
You gotta pay to play man. A front mount is going to be 1500 more and you still wont get injectors, or FMIC. Start saving your pennies.
detroit speedworks turbokit (also known as the livernois turbokit) is a front mount kit, with injectors and a FMIC... $4995
Old Nov 20, 2006 | 10:41 AM
TXsilverado's Avatar
i think they stopped production on them though. if i had the cash to swing thats the kit i would want.
Old Nov 20, 2006 | 10:47 AM
BlackGMC's Avatar
Resident Retard
I have a question about the oil pump. Could the stock oil cooler lines be used to feed and return the oil from the cooler?
Could you tap into this? I got this from someones for sale add, it is the oil cooler/sending unit.
Old Nov 20, 2006 | 11:06 AM
kbracing96's Avatar
No, the oil NEEDS to gravity drain in to no pressure out of the turbo and be pumped back to the motor. You can't have positive pressure after the bearing journals in the turbo, or it will push oil past the seals into the intake and exhaust of the turbo. The oil cooler lines like you posted have pressure coming out and going back in as they feed the rest of the bearings in the motor.
Old Nov 20, 2006 | 11:24 AM
BlackGMC's Avatar
Resident Retard
Oh, I was just wondering, sounding like a decent idea.
Old Nov 20, 2006 | 12:35 PM
slowec's Avatar
That hose assembly bolts on the same place you tap for the turbo feed. I welded mine in the valve cover. If the design works ...aint broke don't fix.
