OK What did i do wrong???!!!
Old Mar 28, 2008 | 03:32 PM
beastolds455's Avatar
Exclamation OK What did i do wrong???!!!
Well i tried to reassemble the pushrods and rockers, got everything back
together and the engine turns over to freely like i have no compression
so i pulled the valve covers only to find i had some loose rockers
i tighten them up but same thing somebody correct me if im wrong
but this should be a hydralic roller so there should be 0 lash but it still
does the same thing advice plz.
Old Mar 28, 2008 | 03:36 PM
sickREDsierra's Avatar
what torque spec did you use on the rocker bolts?
and did you put any loc-tite on them? they need a small dab.
Old Mar 28, 2008 | 03:42 PM
joshua022's Avatar
you need to rotate the motor a couple of times after torqueing them the first time and then re-torque them.
Old Mar 28, 2008 | 03:43 PM
OnyxSilveradoSS's Avatar
did you put the pedstals back?
Old Mar 28, 2008 | 03:44 PM
Mangled03gmc's Avatar
Baltimore Whore
Also 22ft lbs they need to be, turn the motor over a few times, then go over them again..
John
Old Mar 28, 2008 | 03:51 PM
Default Wow That Was Quick
Thanks guys Dont laugh i did them buy hand so i will go and get a torque
wrench but this is the same sound u here when u lose a timing chain but
thanks will do i hope this works ive got class on monday!!
U GUYS ARE GREAT I ACTUALLY LIKE THIS BOARD SO INFORMATIVE!!!
Frank
joshua022's Avatar
What did you change??? the cam??heads?? telling us that might help us find your problem.
Old Mar 28, 2008 | 03:54 PM
La Palomita's Avatar
ok what do u guys meen by ''turn the motor over''
Unhappy No its in another posts
I was trying to find my misfire and thought it may have been a pushrod
but i think its a intake valve major backfiring over 2800rpm and it backfired
so bad it blew the back out of the air flow gauge on my stock airbox lid!!!
Old Mar 28, 2008 | 03:56 PM
joshua022's Avatar
rotate the crankshaft...thus rotating the cam which move the rockers
