Which oil weight?
Old Aug 24, 2006 | 06:02 PM
14 Second Truck Club
Default Which oil weight?
My truck is running hot due to fan harness not letting the 2nd fan come on high when the a/c is running. Changing oil in the morning before I go to Dallas. ~3 1/2 hr drive. Would it matter if I used 5W30 or 10W30 Mobil 1? I don't think it makes a difference, just wondering if one would run cooler than the other.
Thanks.
Old Aug 24, 2006 | 10:36 PM
SBTork's Avatar
10W30 will be thicker, thus reducing temps, but it may not be noticable.....but Karo syrup is hard to beat
Old Aug 24, 2006 | 10:43 PM
NeverSatisfied02's Avatar
Id run Mobil 1 5w30.
Old Aug 24, 2006 | 11:14 PM
ap2002's Avatar
10-30 is what I use - mobil 1 -
by the way I am having the same problems with my harness?? as long as im driving it , its ok but if I come into traffic and sitting there with the a/c on it will start heating up and I have to turn off the a/c and open the windows... I really getting tired of it, I wonder if there is any way to just leave both of them on all the time??
Old Aug 24, 2006 | 11:49 PM
Kinda curious, why 10w30? These truck call for 5w30.
Old Aug 25, 2006 | 12:58 AM
When I turn my toggle on, both fans come on low. This works great at night, when I usually have my windows down anyways. During the day if I have the toggle on with both fans on low, turn the a/c on and the driver side fan stays on low, while the passanger fan comes on high. I think it would be fine if both fans would come on high with the a/c on like their supposed to. How do your's work?
Old Aug 25, 2006 | 12:59 AM
Thanks for the replies, I went ahead and bought 10W30.
Old Aug 25, 2006 | 01:42 AM
If im running mobil 1 5w30, its ok to swap to mobil 1 10w30 next change isnt it?
Old Aug 25, 2006 | 06:36 AM
twobit's Avatar
Hey Ricard, what are you gonna be doing in Dallas?
Old Aug 25, 2006 | 06:55 AM
Beastofa327's Avatar
10w30 the higher vicosity will protect from friction hence less heat, but you mpg will be down a little.
