Oil Pump Relief or Bad Sensor???
Old Oct 31, 2016 | 09:39 AM
CF7GO's Avatar
Default Oil Pump Relief or Bad Sensor???
So this weekend I took my truck to the store. Came outside, started the truck and wham....No Oil Pressure. I instantly shut it off. Once I got it back to the shop for ***** and grins I started it again...Full Oil Pressure..
I have heard of the relief in the pump sticking open. And also heard of bad sensors.
What would you guys do? Hook up a mechanical gauge and test it? Change the sensor? Pull the pan and pump and check into it?
If the relief sticks open...is there a chance it can close and work again?
I do have a L96 6.0L that is almost ready to go into the truck anyways. But its not fully ready.
I just don't want to be far away from home and have no oil pressure again.
Old Oct 31, 2016 | 09:56 AM
Gbrown1320's Avatar
Definitely put a mechanical gauge on it and verify. I wouldn't rule out a failure of the oil pump pick-up O-ring either. Its a notorious little problem on these engines.
Old Oct 31, 2016 | 10:00 AM
CF7GO's Avatar
I know the red oring is good. Ive driven it for 7k miles with no issues. And i can't see that failing, then working again. That's what lead me to think it's the sensor or the relief....
CF7GO's Avatar
Are there any places I can put a mechanical gauge besides the back of the intake?
Old Oct 31, 2016 | 10:26 AM
Gbrown1320's Avatar
If I remember correctly, I think there is a spot to access oil pressure on the driver's side front of the block, about level with the crank, just rear of where the timing cover meets the block. I think there's an allen headed plug in the port.
Old Oct 31, 2016 | 10:44 AM
CF7GO's Avatar
Found it! Just have to figure out what size that port is! Thanks!
