Oil pump change after AFM/DOD delete?
Old 02-22-2018, 08:28 PM
FFDP's Avatar
It doesn't really matter. The standard or high volume pump will work just fine.
GM mixes parts up on nearly every single engine they made.
Old 02-22-2018, 09:00 PM
Registered User
Walters0687's Avatar
I’ve ordered a Melling 10295 (standard volume high pressure). Probably just leave the red spring in there as it comes and see where the oil pressure is at when the it takes it’s first breath
Old 02-24-2018, 07:21 AM
swathdiver's Avatar
There's a pdf on the internet called Rebuilding GMs Gen IV Engine. It's well worth reading. The Melling M365/12612289 is my choice, stock in my 2009 LC9.
Old 02-24-2018, 07:59 AM
Registered User
I’ve read about those but where do I find them?
Old 02-24-2018, 01:50 PM
swathdiver's Avatar
Find what?
Old 02-28-2022, 09:13 AM
Registered User
Bennett258's Avatar
Originally Posted by 07NBSChevy
Hey guys, so before I slap the engine back in my truck, I just wanted to double check my oil pump choice. I did a AFM/DOD delete along with a BTR Truck Stage 2 cam. Engine is a Gen4 Iron block LMG 5.3, I replaced my oil pump with a new GM stock one, #12586665, which is a common pump used in the LS1, LS2, LS6 and so on. Now should I have used a better pump such as Melling 10295 (Standard Volume, High Pressure) or Melling 10296 (High Volume, High Pressure) ? If it matters my shift RPMs will be set at 6k and Max would be 6200RPM. Before I removed the engine at hot idle I had around 22-25PSI and anything above 1800 RPM I had 45-50PSI.
I just rebuilt my 2010 5.3 engine. I replaced the oil pump with the Melling high volume pump. I made sure my pickup tube O-ring was a tight fit. My oil pressure is good until the engine reaches operating temperature, then it drops. Idle when cold is 45-50 PSI. Idle when at operating temperature (210') is15-20PSI. I have a check engine light that will come on occasion indicating low oil pressure. I put a delete kit on it and plugged the hole where the relief valve went. Driving down the road the oil pressure will vary from 25PSI -60PSI depending on RPM's. At 55 it's about 30-40 PSI. The screen and gauge have been verified with a mechanical gauge.
Would this be a bearing clearance issue?
Any suggestions?
Old 02-28-2022, 01:31 PM
3wide's Avatar
My three would be, thrust retainer plate, barbell, and or O-ring.
Old 02-28-2022, 01:46 PM
swathdiver's Avatar
Any suggestions?
What is the part number of the pump? There are several labeled high volume.
Old 03-28-2022, 04:20 PM
Smithsonite's Avatar
Any suggestions?
I'm a little late here, but I recently experienced low oil pressure on my Gen IV due to the Amsoil 15K50 oil filter. Apparently they filter TOO good, and become stopped up badly long before the service interval. Mine was barely at 7k miles. I was planning for an engine swap when the exact same thing happened to my dad's '19 Ram Hemi (takes exact same filter). His threw the light on for "low oil pressure". After a simple filter change fixed his issue, I said to myself, I wonder if that would fix mine? Sure enough, it did! I couldn't believe that's all it was. The gauge was trending 20 psi or so lower than it ever has in the 15 years I've owned it. Even cold with Signature Series 10w-30 in the crankcase and just above idle, my pressure would barely reach 40 PSI. After the filter change it was back over 55 PSI when cold just above idle.
Amsoil took back my unused filters and refunded them, but didn't reimburse me for the oil I used. They also didn't reimburse me for the 3 different vehicles I had to change filters on (All with the same issue) after they said they would. I was a bit ticked about that. Just FYI ...
