Oil pump
Old May 26, 2008 | 10:07 PM
1989k1500's Avatar
Default Oil pump
Im building my 6.0 in the next week or so, and Im wondering about the oil pump when I put it back together. Will this pump get me benefit over the stock one or is it not worth it?
http://cgi.ebay.com/ebaymotors/Parts...3756.m20.l1116
BTW sorry if I was not supposed to put an ebay link in here, I can remove it if I need to.
Old May 26, 2008 | 10:15 PM
hirdlej's Avatar
I wouldn't, why would you want to? A stock pump will put you well over 70PSI at WOT. A high vol pump will just put more load on the crank and being a parasite on HP. The stocker is just fine. Leave well enough alone
Old May 30, 2008 | 12:48 AM
rush7's Avatar
My oil pump in my Camaro went out about 2 years ago so I opted to replace it with a Texas Speed ported LS6 pump. I was happy with the switch as the oil pressure ran higher at slower engine speeds. I'm of the opinion that if you can get more oil flowing you can better protect your investment and that would outweigh the very minor loss of horsepower you might lose as hirdlej stated (I suppose this could happen). In my case it was good insurance and peace of mind for me. I just don't know if I would have switched out the pump if I didn't need to because of the cost.
Old May 30, 2008 | 01:45 AM
Thumbs up
That is the pump you want dude! Just leave the regular psi spring in. That is the pump I am going to use on my 6.0.
Old May 30, 2008 | 09:47 AM
thunder550's Avatar
High on diesel fumes
I would not do a high volume pump. The stock or stock replacement pumps are fine. I'm using a Melling stock replacement pump. I have been warned about high volume pumps sucking the pan dry, although I have never heard of this actually happening.
Old Jun 6, 2008 | 01:01 AM
1989k1500's Avatar
I ended up with a factory pump, its some updated version or something I dont remember, its whatever Zippy ordered.
Heres the p/n 17801830
pupi305
Sep 14, 2015 11:40 AM
Tigger Welder
Sep 2, 2015 08:17 AM
JordanH
Aug 8, 2015 07:59 PM
Ammadien
Jul 22, 2015 08:50 PM
Ferocity02
Jul 17, 2015 07:05 PM
