Oil pressure goin past 80! Sending Unit?
Old Mar 15, 2008 | 10:37 PM
04RST's Avatar
Default Oil pressure goin past 80! Sending Unit?
My oil pressure gauge on my dash recently started sitting at 40 at idle and going way past 80 upon load. I checked my cluster gauge with my buddy's interceptor gauge and they read the same. I have been searching and it seems like it may possibly be the sending unit.... Where exactly is it located and does anyone have directions how to change it?
My other concern is that my oil on my dipstick has gone down about 1/4 to 1/2 a quart in about 400-500 miles of driving. Does it sound like something more then a sending unit?
Old Mar 15, 2008 | 10:48 PM
TouchOfEvil04's Avatar
not sure bud, my trucks both sit a 40 while i idle and go up as i give it more gas....
oil consumption well could be a leak, pcv system....did you recently change your oil and go from the small filter to the big one?
Not sure but maybe me tossing out ideas can help out ya know.
Old Mar 15, 2008 | 10:52 PM
dirt track racer 81's Avatar
mine pegs out when i floor it
Old Mar 15, 2008 | 10:53 PM
69Boss302's Avatar
mine goes all the way over too. After 6 years and 177,000 miles, I think it's ok.
Old Mar 15, 2008 | 10:58 PM
04RST's Avatar
Mine never used to peg out.....used to sit at 20 at idle, 40 when cruisening and 60 when getting on it. IDK i'm a bit concerned. I havent changed the oil recently. It only been like 1000 miles since my last oil change (5 months ago royal purple 5w30) it sits in my garage 1/2 the year. Thanks for the quick replies. Anyone else have anything?
Old Mar 15, 2008 | 11:23 PM
budhayes3's Avatar
PT's Slowest Truck
Mine has always acted the way you describe, just above 40 @ idle, 60 cruising, and over 80 @ WOT. I know that the factory gauges aren't the most accurate though. As for oil consumption, if there's no leaks you may be sucking oil through the PCV system, which is very common on the GENIII engines. I have an oil catch can to help combat the excessive oil consumption problem on mine. Of course worst case scenario would be oil burning elsewhere, such as past the rings, but if the engine has low miles and been well maintained, I doubt that's the issue.
Old Mar 15, 2008 | 11:33 PM
04RST's Avatar
The truck only has 45000 on it. I am concerned bc I am wanting to do my cam swap in the next few weeks and dont want to order the parts if something is wrong with the motor. Thanks for your input.
superchomper2003
Aug 26, 2015 09:39 AM
05GMC4.8
Aug 7, 2015 09:55 PM
Gadgetized
Jul 22, 2015 11:55 AM
SumtinCoo
Jul 16, 2015 10:40 AM
