Oil on plugs 5.3
Old Jun 12, 2018 | 05:37 PM
Crysis450's Avatar
Default Oil on plugs 5.3
I have a gen 3 5.3 and i recently had the heads resurface due to a head gasket and we also replaced the lifters. Now i can hear like a knocking im not sure what it is but sounds like the driver side i remove the plugs and #3 add oil all over the threads and electroid could this be a bent valve or maybe push rod rockers seem find
Old Jun 13, 2018 | 06:53 AM
madmann26's Avatar
That’s not a good sign.
I’d start with a compression test to see what the psi is. I’m betting it’s low.
Might as well do all 8 and see what the variance is.
Old Jun 13, 2018 | 08:35 AM
Wolftrk99's Avatar
Oil on the is either a stuck oil ring on the piston or a valve stem seal.. be willing to bet if it was not oil fouled before its a torn valve stem seal
Old Jun 13, 2018 | 10:05 AM
Crysis450's Avatar
What will be the ticking
Old Jun 14, 2018 | 12:28 AM
Wolftrk99's Avatar
Lifter or maybe a loose rocker.... could even be something with the valve spring... just recently had to deal with that on my yukon....
Old Jun 14, 2018 | 12:30 AM
Wolftrk99's Avatar
I also agree with madmann about a compression test and maybe a vacuum guage to see what is truly going on
Justhereforinfo
32
May 30, 2018 05:24 PM
Preston129
Oct 8, 2010 07:12 PM
TX_Silverado
May 4, 2004 12:50 AM
Hit Man X
Jul 7, 2003 01:10 PM
racerfoo
Apr 15, 2003 09:09 PM
