Official GM Gasket , Seal , Sensor Part Number Thread...
Unfortunitaly Most of the dealer guys are not that helpfull and I don't have the spare cash to dish out for a complete kit right now... Also we lost chevracer83 from the GM parts business so getting some of this info can be hard. Maybe Zippy can get you that kit Number... Please LMK if you get it so I can add it.
I used to work at a GMC dealership and still have very good connections...unfortunately no more access to Dealerworld. However, I can get part numbers for hard to find stuff if you need it. just let me know.
See what you can do on a complete gasket kit part numbers for 4.8L/5.3L - 5.7L and 6.0L
Some new up dates to the list.
I Needed the room so I had to move these #'s down.
Found under 1500HD starting in 2001 , 2WD SS, and VHO trucks with RPO option AXN from Late 05-07 Classic. Parts Might cross for GMT-900 07- up
The 1500HD uses the large diameter 8 lug axle. The length is slightly different VS. The 98-Below style. I can not track down every possible part number as some have been discontinued.Please check part numbers with your dealer for your vehicle or custom application *****BEFORE ORDERING!!!*****
NOTE: The Older style 9.5 SF will have different Axle seals, Axle bearings, and axle shafts. The pinion nut is also a different thread between the years. At some point the Pinion seal and Yoke changed as well around 1998. So you will need to use the correct seal with the correct yoke.
14 BOLT 9.5 SF Part Numbers
#3920486 -U Joint Straps for 1350 U Joint??? All years SOLD AS A SINGLE (2 Required)
#11548472 -U Joint Strap bolt 5/16 in. 24TPI 1.34 Length Silver RPO AXN SOLD AS A SINGLE (4 Required)
#14018700 -U Joint Strap Bolt 5/16 in. 24 TPI 1.37 Length Black Oxide SOLD AS A SINGLE (4 Required)
#26060414 -Axle Shaft LEFT OR RIGHT 8 lug
#88967013 -Axle Shaft LEFT OR RIGHT 05-07 6 lug RPO AXN
#15552844 -Pinion nut 86-00 OBS ???
#88891763 -Pinion nut 99-07 NBS ???
#26063649 -Rear Diff Cover Gasket
#19133288 -Rear Diff Cover
#457108 -Inner Pinion bearing
#9417781 -Outer Pinion Bearing
#11505123 -Diff Side Bearing SOLD AS A SINGLE (2 Required)
#9439561 -Wheel Bearing 88-98 99-up 1500HD Large with 1.703 Shaft SOLD AS A SINGLE (2 Required)
#19180849 -Axle Seal 88-98 99-up Large with 1.703 Shaft SOLD AS A SINGLE (2 Required)
#12479031 -RPO AXN Wheel bearing Small With 1.622 shaft 2005-Up SOLD AS A SINGLE (2 Required)
#12471686 -RPO AXN axle seal 2005-Up SOLD AS A SINGLE (2 Required)
#12479321 -Carrier Gear kit W/O Limited Slip
#26060414 -Carrier Pin W/O Limited Slip
#12471409 -Carrier Gear kit W Limited Slip
#14012700 -Carrier Pin W Limited Slip 148.0MM
#14039025 -Carrier Pin W Limited Slip 144.78MM RPO AXN
#12337979 -Carrier pin bolt
#12337937 -Gear side washer W/O Limited Slip
#14039026 -Pinion Washer W Limited Slip
#12471390 -Right Clutch kit for Limited Slip
#12471408 -Left Clutch kit for Limited Slip
#14012746 -Axle C-clip
#14012691 -Crush sleeve spacer 35.5MM I.D. X 16.3MM WIDE
#26064029 -Pinion Seal 97- up RPO AXN
#12470384 -Pinion yoke kit RPO AXN
#12569167 -L92 Intake Rocker Arm. SOLD AS A SINGLE
#10214664 -L92 Exhaust Rocker Arm. SOLD AS A SINGLE
#12600936 -L92 Rocker Arm Support Stand. SOLD AS A SINGLE
#12560961 -Rocker Arm Bolt for 4.8's, 5.3's, LS1, LS6, LS2, L76, and L92. Does not fit the LS7!
#12571595 -L92 Hydraulic Roller Two-Stage Valve Lifter SOLD AS A SINGLE
#17122490 -L92 Hydraulic Roller Two-Stage Valve Lifter SOLD AS A SINGLE
#12571596 -L92 Front Lifter Guide SOLD AS A SINGLE
#12571608 -L92 Rear Lifter Guide SOLD AS A SINGLE
#89018058 -L92 spark plug wires
#12600767 -L92 Water pump
#12551926 -L92 Water Pump Bolt SOLD AS A SINGLE
#12587395 -L92Water Pump Inlet
#11516480 -L92 Water Pump Inlet Bolt SOLD AS A SINGLE
#12584727 -L92 Block
#12560272 -L92 Main Cap Bolt SOLD AS A SINGLE
#12560273 -L92 Main Cap Stud SOLD AS A SINGLE
#12556127 -L92 Main Cap Side Bolt SOLD AS A SINGLE
#12563918 -L92 Dipstick Tube
#12574888 -L92 Dipstick
#11519772 -L92 Long Cylinder Head Bolt M11 x 2 x 100 SOLD AS A SINGLE
#12558840 -L92 Short Cylinder Head Bolt M8 x 1.25 x 45 SOLD AS A SINGLE
#12590771 -L92 Intake Valve SOLD AS A SINGLE
#12582719 -L92 Exhaust Valve SOLD AS A SINGLE
#12557840 -L92 Crankshaft Balancer Bolt, M16 x 2.0 x 103
#12576652 -L92 Crankshaft Balancer
#12556582 -L92 Crankshaft Sprocket
#12561513 -L92 Crankshaft Key
#12584997 -L92 Crankshaft Assembly
#12602448 -L92 Flywheel
#12585994 -L92 Camshaft Position Actuator
#12588151 -L92 Camshaft Position Actuator Valve
#11561283 -L92 Camshaft Bolt, M16 x 1.5 x 63
#12482063 -L92 Valve Stem Seal Kit
#12558760 -L92 Oil Pan Gasket
#12610046 -L92 Head Gasket, 4.065" Bore SOLD AS A SINGLE
#12588372 -L92 Water Pump Gasket SOLD AS A SINGLE
#12556437 -L92 Camshaft Retainer w/ Seal
#12587099 -L92 Crankshaft Balancer Reverse Lip Seal
#12570125 -L92 Knock Sensor SOLD AS A SINGLE
#12591720 -L92 Camshaft Position Sensor
#12585546 -L92 Crankshaft Position Sensor
#15326388 -L92 Engine Coolant Temperature Sensor
Thanks Man!
