OBX "longtubes"
Old Jan 10, 2007 | 06:31 PM
  #91
BlackGMC's Avatar
Resident Retard
Do you have to use a Tig to weld SS? Could you use a Mig with the right wire?
Old Jan 10, 2007 | 06:40 PM
  #92
truckmann's Avatar
Looks like it is possible to mig SS.
http://www.lincolnelectric.com/knowl.../migweldss.asp
Old Jan 10, 2007 | 06:42 PM
  #93
BlackGMC's Avatar
Resident Retard
Thanks it looks like you have to use a 98/2 gas mix.
Old Jan 11, 2007 | 12:33 AM
  #94
Soon2BeDraggin's Avatar
Originally Posted by 99Silver6.0
Sweet deal. You could always have that Y tigged up real nice!
Why did you hack off your thumb?!?!?
well... i didnt really do it on purpose. i some how cut it on the exhaust clamps, cant find where it cut me, or anything, couldnt even find the chunk of my thumb either :dunno:
i dont have plugs for the 2 other bungs yet, but i kindof ghetto rigged it just so that i can drive it to work without it being too bad. took it for a test drive and i am happy for the most part, but at certain RPM's, it sounds really raspy almost like a popping maybe? and i'm not happy with that part. but i am going to wait till i get everything else fixed before i make my final judgement on them.
two more things:
what is the easy trick to the spark plug wires?
and what could cause the raspy/popping type of noise?
truck has SB intake, these headers and then 3in from the Y-pipe back with a magnaflow muffler 5x8x14 (#14219)
Old Jan 11, 2007 | 01:28 AM
  #95
well, after doing some searching, i think i might know what the problem is, i may have cracked a spark plug or damaged a plug wire i thought i was careful, but maybe i did hit one. so i'm going to try and swap those out in the next day or two
which spark plug/wires should i get? and where can i get the boot protectors to protect them from the headers?
-thanks
Shaun
Old Jan 11, 2007 | 04:24 PM
  #96
Smoke T/A's Avatar
Does the drivers side have that funky looking bend on it? Can you post some pics of them installed?
Old Jan 11, 2007 | 05:10 PM
  #97
Phantom's Avatar
11 Second Club
i cracked a couple plugs when i put my headers on...prolly the poppin noise
Old Jan 11, 2007 | 05:31 PM
  #98
kbracing96's Avatar
For the extra O2 holes, go to the parts store and get some 14mm x 1.5mm oil drain plugs. They will screw right in.
Old Jan 11, 2007 | 11:27 PM
  #99
yeah, i was told that a oil drain plug for a toyota 22r would be a perfect fit, but it wasnt even close, so i dont know if they gave me the wrong plug or what.
and yes, they have that funky bend on the drivers side.
Old Jan 12, 2007 | 12:05 PM
  #100
LARRY01Z28's Avatar
get some pics for us if you can thanks larry
