o2 sensor
Old Oct 23, 2006 | 05:03 PM
slownlow4.8's Avatar
Default o2 sensor
where can i buy o2 simulators and will i need 1 or 2 with l/t headers,ory,and 1 hi flow cat?
Old Oct 23, 2006 | 07:07 PM
anyone?
Old Oct 23, 2006 | 07:30 PM
nightrunner's Avatar
Mr. Obvious
i think you need to keep your front o2s for your pcm to operate correctly and to provide the correct air/fuel mixture
the rear o2s are the ones you delete
unless you are running speed density tuning and im not even for sure on that
Old Oct 23, 2006 | 08:51 PM
blake2kz71's Avatar
just go ahead and get a tune. i considered the o2 sims before i cut my cats off but i just dealt with it running rich for 2 weeks and the ses light staying on till i got a tune. no you dont need the rear ones but the fronts are required.
Old Oct 23, 2006 | 09:24 PM
jakebdb56's Avatar
simulators aren't worth the money, just leave the o2's in the exhaust and disable them.
Old Oct 23, 2006 | 09:27 PM
blake2kz71's Avatar
well with the pacesetters which im guessing your gona get they dont come with rear bungs. I just disconnected mine and ziptied the wires to the frame.
Old Oct 23, 2006 | 10:18 PM
brodystruck's Avatar
It's been a while since I installed mine, but I coulda sworn the ORY had a bung for the rear O2s...
Old Oct 23, 2006 | 10:23 PM
blake2kz71's Avatar
well i put mine on 2 weeks ago and i can say for sure they dont but maybe they changed the setup or something.
Old Oct 24, 2006 | 11:45 AM
so if i disconnect them it will be fine
Old Oct 24, 2006 | 01:49 PM
KY_BOB's Avatar
Yes, you will be fine but will have a SES light till you have it tuned and the codes for the rear sensors turned off. It will run fine.
