NX 150 wet shot
Old May 17, 2004 | 05:11 AM
Deckhand's Avatar
Default NX 150 wet shot
I am planning to hook up a NX wet kit here soon. Before I do, I was wondering if I need to get any other stuff before I hit the spray. You think my 4.8L can handle this? or should I step down to a 100/125? I will be using a WOT microswitch.
1) Window Switch - Do I really need one?
2) Fuel Pressure Saftey Switch - Need that too?
Also, on my 1st run.. if I spray through the shifts, will my tranny ever see the light of day again? If not, what would be a safe shot to spray through the shifts.
Any suggestions or tips?
thanks!
Old May 17, 2004 | 05:20 AM
Sport Side's Avatar
hey,
read this. you might wanna get one.
LS1 Timing Tuner
should help saving your tranny
Old May 17, 2004 | 06:03 AM
mudz5.3's Avatar
Yeah, you might want to get one of the tuners. Its basically a progressive controller that allows you to run a decent size shot without the initial hit if you don't want it. I would recco a 100 shot for the 4.8 if you don't the the tuner. I would also recco the window switch incase you hit the limiter while spraying (all n20, no fuel!!), The safety switch would be a nice addition also. If your worried about the trans, as you should be. Get a Transgo shiftkit and billet servo's installed to help the trans from slipping with the additional power.
Old May 17, 2004 | 12:28 PM
Deckhand's Avatar
you think a small 50 shot or so, while shifting, etc.. will be cool until i get all the other **** to handle a 150?
Old May 17, 2004 | 12:43 PM
mudz5.3's Avatar
I think that would be fine, if thats possible. I would definatley recco a shift kit and billet servo's though, no matter how much n20.
Old May 18, 2004 | 02:13 AM
13 Second Truck Club
From: Pueblo de Nuestra Señora la Reina de los Ángeles de la Porciúncula
If you want a progressive controller, then get one like the NOS progressive controller. The Ramcharger does have a timer delay, but it doesn't gradually increase the shot like the NOS controller does, from what I've read at least.
The Ramcharger timing tuner has a built in window switch, so you don't have to buy another one.
Richard(Oxidizr) has the NOS progressive controller, maybe he'll chime in about it
twake_410
Apr 14, 2016 09:58 PM
cheyenne383
Nov 13, 2015 09:24 AM
gmcyukon
Oct 3, 2015 11:03 PM
redbird555
Sep 30, 2015 09:28 AM
Slammed silverado
Sep 28, 2015 06:14 PM
