Now I Have My Starting Problems
Old Aug 7, 2005 | 07:54 PM
litreddevil's Avatar
Banned
Default Now I Have My Starting Problems
Well The New Motor Is In Just Waiting On My New Stall.i Hook Up Everything And Get Ready To Start It And Turn The Key Nothing,fuel Pump Comes On And All The Dash Lights Come On But No Start.jumped The Wires @ The Relay And It Starts.brand New Ign. Switch Back In Jan. But The Truck Has Been Down Since Feb.
I Just Don't Know It Has A Code B2961 (key In Ign. Malfuntion.
I Get My Valve Cover Spacers Tomorrow From More Preformance.
The Little While It Ran It Had Slow Throttle Responce.
HAS ANYONE HAVE THIS BEFORE
Old Aug 7, 2005 | 08:00 PM
ranwalk's Avatar
Document ID# 741645
2001 Chevrolet Chevy C Silverado - 2WD
DTC B2961
Circuit Description
The body control module (BCM) monitors the ignition key alarm switch. When the key is in the ignition, the ignition key alarm switch is closed (signal circuit is low). When the key is not in the ignition, the ignition key alarm switch is open (signal circuit is high).
Conditions for Running the DTC
The ignition is ON.
Conditions for Setting the DTC
The ignition 1 input is active and the key in ignition switch signal circuit is inactive (signal circuit is high).
The conditions above must be present for more than 5 seconds.
Action Taken When the DTC Sets
The BCM stores DTC B2961 in memory.
Conditions for Clearing the DTC
The DTC becomes history when the fault is no longer present.
A history DTC will clear after 100 malfunction free warm-up cycle.
The BCM receives a clear code command from the scan tool.
Step
Action
Yes
No
Schematic Reference: Audible Warnings Schematics
Did you perform the Instrument Cluster Diagnostic System Check?
Go to Step 2
Go to Diagnostic System Check - Instrument Cluster
Install a scan tool.
Turn ON the ignition, with the engine OFF.
With the scan tool, observe the Key In Ignition parameter in the BCM data list.
Does the Key In Ignition parameter display Yes?
Go to Step 3
Go to Step 4
Observe the Ignition 1 parameter in the BCM data list.
Turn OFF the ignition.
Does the Ignition 1 parameter display ACTIVE with the ignition OFF?
Go to Step 7
Go to Step 11
Disconnect the BCM connector C2.
Connect a test lamp between the key in ignition signal circuit and battery positive voltage.
Place the key in the ignition.
Does the test lamp illuminate?
Go to Step 8
Go to Step 5
Test the key in ignition signal circuit for an open or a high resistance. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Did you find and correct the condition?
Go to Step 12
Go to Step 6
Test the ground circuit of the ignition key alarm switch for an open or a high resistance. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Go to Step 12
Go to Step 9
Test the ignition 1 voltage circuit for a short to voltage. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Go to Step 12
Go to Step 11
Inspect for poor connections at the harness connector of the BCM. Refer to Testing for Intermittent and Poor Connections and Connector Repairs in Wiring Systems.
Go to Step 12
Go to Step 11
Inspect for poor connections at the harness connector of the ignition switch. Refer to Testing for Intermittent and Poor Connections and Connector Repairs in Wiring Systems.
Go to Step 12
Go to Step 10
Replace the ignition key alarm switch. Refer to:
Ignition and Key Alarm Switch Assembly - Disassemble - Off Vehicle in Steering Wheel and Column - Standard
Ignition and Key Alarm Switch Assembly - Assemble - Off Vehicle in Steering Wheel and Column - Standard
Ignition and Key Alarm Switch Assembly - Disassemble - Off Vehicle in Steering Wheel and Column - Tilt
Ignition and Key Alarm Switch Assembly - Assemble - Off Vehicle in Steering Wheel and Column - Tilt
Did you complete the replacement?
Go to Step 12
11
Important
Perform the set up procedure for the replacement BCM.
Replace the BCM. Refer to Body Control Module Replacement in Body Control System.
Go to Step 12
Use the scan tool in order to clear the DTCs.
Operate the vehicle within the Conditions for Running the DTC as specified in the supporting text.
Does the DTC reset?
Go to Step 2
System OK
Document ID# 741645
Old Aug 7, 2005 | 08:31 PM
Banned
Thanks Man
I JUST WENT CHECK IT AND KEY ON IN THE IGN IT READS NO KEY SO TOMORROW I WILL HAVE SOME DAY LIGHT TO WORK ON IT BUT IT THINK MY BCM IS BAD.
ferrellrooster
Mar 6, 2025 03:22 PM
treylittlefield
Jan 24, 2016 07:38 PM
chevy6.0fan
Aug 20, 2015 07:10 PM
WarbirdLS1
Aug 8, 2015 10:53 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
