Not too sure this will fit under my stock hood..
Thought I'd share a few more pics of the intake setup I am switching to.. I also marked on both the intake opening on the Super Vic and Vic JR that I have with the Felpro gasket to give you a better understanding of the port differences. Hopefully I don't loose too much bottom end. But then again, the 4,900 verter probably won't care..
What fuel rail looks better? The black one ot the Edelbrock one? I know I need to do something about the valve covers.. http://73-ls1.com/63truck/cleanup/engine01.jpg http://73-ls1.com/63truck/cleanup/engine02.jpg http://73-ls1.com/63truck/cleanup/engine03.jpg http://73-ls1.com/63truck/cleanup/engine04.jpg Here is what the gasket looks like against my heads.. Also looking down the intake port while sitting on the motor: http://73-ls1.com/63truck/cleanup/headtogasket01.jpg http://73-ls1.com/63truck/cleanup/headtogasket02.jpg http://73-ls1.com/63truck/cleanup/portpic01.jpg http://73-ls1.com/63truck/cleanup/portpic02.jpg http://73-ls1.com/63truck/cleanup/portpic03.jpg Here is the height of this set up: http://73-ls1.com/63truck/cleanup/height.jpg Finally the Vic JR vs Super Vic gasket.. http://73-ls1.com/63truck/cleanup/vicjrporttogasket.jpg http://73-ls1.com/63truck/cleanup/su...rttogasket.jpg |
Nice looking setup. It should fit. I have that exact setup with a carb hat on mine, minus the nitrous plate and I still had a couple inches of clearance. Except....I just realized yours is not going into a 99-07 truck :jest: And I just realized you have an extra spacer in there too. Shit :D :D
I like the look of the Edelbrock fuel rails personally....it gives some color and character to all of the bare aluminum up there, and it also somewhat matches the nitrous plate. |
Your running a Super Vic or a Vic JR? The Super Vic is a bit taller..
Vic Jr.
So when I said "exactly" the same setup in my first post, I really meant "not even close to the same" setup :jest: |
Idk man thats gonna be awful close if it does..........
shaker
Time for the snorkle hood.....
Kick a** setup man!!! I bet the upper rpms will feel plain nasty with that setup... |
Killer engine, I like the Edelbrock fuel rails myself
:drool:
Nice. Those intakes are bad ass looking!!!
