NNBS intake PCV piece
1 Attachment(s)
I finally got almost everything together to get my NNBS intake on but there is a piece that goes into the top of the manifold that I didn't get. It's the fitting that the PCV hose from the drivers side valve cover hooks to. Does anyone know the part number for that so I can get it from the dealership? Or another solution?
Here's a picture of the hole where the part goes. |
https://www.performancetrucks.net/fo...-508470/page3/
It's ghetto but works! I just went to Lowes and bought a 90 elbow and siliconed it in. |
Yeah. That's what I'm about to do. I see you also had to use your old map sensor. I was just took the o ring off the other one and put it on my original one and coaxed it in. We'll see if it seals up but I don't see how it couldn't unless I was boosted.
On a side note, nice avy. |
Originally Posted by axekick
(Post 5028707)
make sure you post a pic on how you did this! i'm gonna be installing my nnbs intake sooner or later
Its the perfect size to tap for 3/8npt....thats what I did and used it for my map sensor.
I was thinking along those lines. Where did you hookup your pcv line?
vent directly on the valve covers
Just go to the dealer and tell them you need the PVC line from an 09 pickup with a 5.3, it's like $11. Chop off the end by the valve cover just above the locking part and the factory hose on the valve cover fits perfect.
5 Attachment(s)
