Nitrous problems
Old Aug 3, 2004 | 12:00 PM
Default Nitrous problems
I posted this on the nitrous section...see if you truck guys can help...here is the link. https://ls1tech.com/forums/showthrea...63#post1616763
Old Aug 3, 2004 | 12:37 PM
Deckhand's Avatar
are you detonating? was the spark plug melted the 2nd time you switched plugs?
Old Aug 3, 2004 | 01:19 PM
383LQ4SS's Avatar
Iron Destruction Director
What octane fuel do you use when spraying. Its definately detonation. But it may be from too much timing (atap it)...a fule issue (check your fuel pressure)..or an octane issue. If you use 87 or 89 octane put some 93 in it and try again.
Better yet...autotap on a dyno with a wideband if possible.
Old Aug 3, 2004 | 01:25 PM
Looney102's Avatar
Sounds like it is not getting enought fuel to me!!. do u have an upgraded fuel system ? If not you should think about larger injectors and fuel rails. Switching to a wet kit could also help.
Old Aug 3, 2004 | 02:24 PM
Deckhand's Avatar
yea, might wanna get some injectors, retard timing.. or just get a wet kit.
Old Aug 3, 2004 | 03:21 PM
Ryan23silverado's Avatar
Is it popping off your intake tube then it cannot read the maf anymore? Is the nozzle pointed straight at the manifold? You are running 91oct at least right?
Switch to a wet shot. It is safer and trust me will give you a ton more torque to the wheels
madmann26
Apr 29, 2020 09:17 AM
dsbodley
Nov 14, 2015 09:46 PM
2002_Z28_Six_Speed
Oct 4, 2015 01:34 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
sTNT971
Sep 26, 2015 06:27 AM
