Nineball? Towing with your setup?
He needs airshocks or bags back there from what I've seen. It sits a little low in the back. As far as 17's and towing, I've towed with s the stock 16's, 17's and 18's. As long as you have at least 5" of sidewall height, it will be fine and barely noticable on ride roughness.
Registered User
Did he have the car positioned perfectly on the trailer, having the car too far forward when we towed with a Lightning had the rear sagging a lot.
I have leafs in back, so I would need airshocks i guess?
The ride is just fine, but since my rear is lowered 2" it sits about 2" too low back there with the car hooked up. The truck sits perfectly level with nothing hooked up, and even the empty trailer brings it down a bit.
I'll probably just do the air shocks like Greg has. Its mostly a cosmetic issue though, the ride is very smooth and no drama.
Tony
Tony
For the record, bags are better. The only reason I like air shocks are they are $70 and bags are $260+/-. The Gabrial airshocks come with a lifetime warranty at Autozone. Yes I have blown them before and am on my third set. The first was destroyed be me and me only. The second set blew a seal on one of them. But since they only take 20 min to change, I chose the cheap route.
LARRY01Z28
Sep 16, 2015 10:02 PM
