Next mods.
Old Jan 17, 2006 | 03:21 PM
4.8redchev's Avatar
Default Next mods.
Well i think im going to go with some 05' electric fans and a custom grind cam.
216/218 .550 114 Lsp will this cam be ok without a stall? im adding a stall but later on or should i do the electric fans and stall first?
Old Jan 17, 2006 | 03:46 PM
virgils4.85spd's Avatar
I would, but youll need a tune to turn the fans on unless you want to do it manually.
Old Jan 17, 2006 | 03:53 PM
4.8redchev's Avatar
how would i do that? i already have a tune do i just need to have it reflashed and the fans programmed in there?
Old Jan 17, 2006 | 04:27 PM
budhayes3's Avatar
PT's Slowest Truck
Yep, your tuner will program to ground pin42 when the pre-determined fan turn on temp is reached. I highly recommend using the Nelson fan harness also, it's really awesome.
As for that cam grind without a stall, if it's for the 4.8 listed in your sig, I'd recommend at least a mild verter. I have a baby cam in my 5.3 (see sig), and it works great with the factory verter, but could really benefit from some form of verter (maybe 2400?).
Klein7
Aug 31, 2015 12:26 PM
mz00516
Aug 23, 2015 12:19 PM
nickpc82
Aug 10, 2015 09:08 AM
Geramontes
Aug 9, 2015 09:32 PM
Ketis
Jul 23, 2015 12:37 PM
