new tbss intake and fast 90mm!
Old Jun 10, 2009 | 06:13 AM
  #21
Tootall's Avatar
Originally Posted by Pewter53
get some tommorow when i take my motor back out.
pics of cable bracket and the fuel connections please !
Old Jun 12, 2009 | 08:59 AM
  #22
Low_LSX's Avatar
Formerly Low_LQ4 - 6/6/10
bump...
Old Jun 16, 2009 | 10:54 AM
  #23
Darkblue5.3's Avatar
im in the process of doing this to my 05 silverado.... buying the TBSS TB, x-link is about $220+, i have the TBSS injectors, but need the injector connectors since alone they will not fit our body style without some sort of modification...and having my TBSS intake ported too... just the runners, its not going to be opened up since i dont know if it is worth it, because i think i have the newer TBSS intake which apparently doesnt have the same outcome as the earlier models would have if they were to be opened up and ported....
Old Jul 23, 2009 | 08:25 PM
  #24
zeake's Avatar
07 NNBS truck intake with nick williams tb. Pic
Old Jul 31, 2009 | 04:45 PM
  #25
truckmann's Avatar
What's the story with all those AN lines on there?
Old Jul 31, 2009 | 05:26 PM
  #26
zeake's Avatar
Crossover tube was modified so it would fit my rails on the nnbs intake. My rails are return style. AN fitting welded onto it by Trick Performance. Then an line run to other rail.
Old Jul 31, 2009 | 06:06 PM
  #27
007gmc's Avatar
so is the tbss and nnbs intake the same part number?
Old Jul 31, 2009 | 06:09 PM
  #28
zeake's Avatar
No. Diff number. Diff intake. It will accept larger 4 bolt throttle body but it is a bit different. I can't say it is a good swap or not yet cause I have not been able to get my truck retuned.
Old Jul 31, 2009 | 10:19 PM
  #29
I was under the impression they were the same and i just used a corvette fuel filter to make my return style fuel lines work with the returnless fuel rail.
Old Jul 31, 2009 | 10:34 PM
  #30
zeake's Avatar
With TBSS intake yes. With this one I am not sure as it is wider up top. I should have taken a pic with TBSS NNBS truck and Lq4/9 intake. All clearly different. I used the AN fittings and line to use my original rails.
