new pushrods with head and cam swap?
Old Jun 30, 2006 | 05:58 PM
Default new pushrods with head and cam swap?
I'm in the middle of putting 317 heads on my 5.3 and changing the cam to the 265 extreme from comp cams. Do I need different pushrods? I also changed the valve springs to the yellow GMPP ones.
Old Jun 30, 2006 | 07:14 PM
99Silver6.0's Avatar
Please tell me your running forced induction of some kind!! Putting these heads on a 5.3 will decrease yoour compression among other things, not beneficial for power here.
Old Jun 30, 2006 | 07:19 PM
v8
17,16,15,14,13,12,11 Drvr
the valves are going to be very close to the side walls of your bore, 5.3 bore 3.77, 5.7 bore 3.9, and going from 62cc heads to 72cc heads going to put you around 8.5 to 8.8 compression, great for forced induction bad for N/A.
Old Jun 30, 2006 | 07:20 PM
Shrouding is another issue, like Kevin explained above.
Old Jun 30, 2006 | 07:40 PM
yeah i'm running a novi 1000. What do you mean by shrouding? So will my stock rods fit?
Old Jun 30, 2006 | 07:42 PM
Ah, ok man. I was scared there for a minute. Are the heads milled at all??
Old Jun 30, 2006 | 07:46 PM
Nope stock except theyre getting a mild port job
Old Jun 30, 2006 | 07:52 PM
I think you'll hate how much of a dog your truck will be with that low of a CR.
Old Jul 2, 2006 | 06:51 PM
Any andwer on weather the stock pushrods will work?
Old Jul 2, 2006 | 07:08 PM
Long as they arent milled yes. 7.4" is fine but I would push it to a 7.425" or 7.43".
