New Lifters?
Old Dec 29, 2005 | 05:47 PM
Bradazz's Avatar
Default New Lifters?
While I have the heads off I want to replace the lifters aswell. What lifters should I buy to replace the stock lifters? Stock OEM or Aftermarket? Any suggestions would be helpful? Also include part numbers if possible. Thanks.
Old Dec 29, 2005 | 06:04 PM
99Silver6.0's Avatar
You can go stock or use the Comp lifters #850-16. I would advise you stay away from the Comp R's though!
Old Dec 29, 2005 | 08:05 PM
white lightning SS's Avatar
If you have over 200 lbs of open pressure on those after market heads I would definetly replace the lifters. I had problems w/ new factory lifters when I installed my heads. It was a pain to find zero lash w/ the weaker spring inside. I used the comp lifters, they work great.
JordanH
Nov 6, 2015 07:42 PM
gmcyukon
Oct 5, 2015 06:20 AM
zblee
Sep 19, 2015 06:33 PM
chvy=power
Sep 8, 2015 11:06 AM
Cowboy Tom
Sep 5, 2015 04:29 PM
