New guy has some questions...
Old Jan 10, 2012 | 04:38 PM
  #31
bitterfitter's Avatar
I do not know what NNBS trucks are, sorry.
So what I am reading on this forum is that the L33 has the better heads, Grafal flat top pistons, good rods, and possibly a better cam. If this is all true, then I am better to rebuild my engine than get another. So it looks like I will reuse my L33. I still need to decide on a mild cam. I will upgrade the springs at the same time. LS6 springs it sounds like. Before I open up this engine; does this engine have roller rockers? I was reading in the brochure and they say it does. Or do all these LS engines?
Do I still need to upgrade pushrods and to LS7 lifters for a nearly stock build?
Old Jan 10, 2012 | 05:40 PM
  #32
I see the LS327 is a warmed over basic 5.3. Looks like a cam and piston change. Now if I take my L33 and put the LS327 cam in it I should be doing better than the LS327 #'s; correct? As I have the same pistons, a better set of heads and would then have the same cam....
---Maybe this is what I am looking for......
Old Jan 10, 2012 | 11:16 PM
  #33
dmelvin's Avatar
NNBS = New New body style - 07+ trucks. a.k.a GMT900.
IMHO I'd go bigger than the LS327 cam. Even if it's just a little bit.
LS327 cam
196/201 - .467/.479
I'd look into something around 208/212 - 216/220. Those cams should give you next to no, if any low end loss, and great power throughout the RPM range.
Old Jan 11, 2012 | 05:13 PM
  #34
I kinda like the TR214/220 or Scoggin Dickeys Z+221. Have any thoughts if I am on the correct track? These both seem to have some torque associated with them but won't kill my driveability everyday.
Old Jan 11, 2012 | 05:40 PM
  #35
dmelvin's Avatar
Personally I'd go with the 214/220 of the two you posted.
Is the truck extended or regular cab?
Old Jan 11, 2012 | 05:52 PM
  #36
Silverado777's Avatar
LS327 cam
196/201 - .467/.479
I have a 208/212 cam and it was a dog off the line. Great HP gains though. I also have 1.75 roller rockers which probably killed the bottom end.
Old Jan 11, 2012 | 07:59 PM
  #37
dmelvin's Avatar
I'm running a 216/220 low lift. I didn't notice a loss of low end, however I also changed heads and added LT's with full exhaust, as well as boosted my CR a hair.
Old Jan 11, 2012 | 08:00 PM
  #38
What about a Trick Flow Track Max LSX cam? Summit has one on sale that looks like this: 216/220 @.050" and .560/.560 lift Says 10.5:1 minimum compression though...
It is going for $300.
Old Jan 11, 2012 | 08:44 PM
  #39
Extended cab
Old Jan 11, 2012 | 08:46 PM
  #40
What is this 212/218 cam I keep hearing about? Where do I find this one?
