New 1000hp. Truck Fuel Systems Now Available!!!
Old Feb 3, 2005 | 06:59 PM
one03sierra's Avatar
Formerly one92rs
Talking
Originally Posted by 02denali
so besides the wire splicing do we retain the use of the bucket or do we have to modify it as well. i was wondering since i have read that when the bucket is modified that the pump can run dry if under 1/4 tank. thanks.
not to be pesky. how about that bucket question speedengineering.
Old Feb 3, 2005 | 07:11 PM
XLR8NSS's Avatar
Adkoonerstrator
Is that long tube with the 90 degree bend fitting on it in the picture a pickup that goes into the stock bucket? This should answer 02's question also.
Looks
Old Feb 3, 2005 | 07:19 PM
Birdie2000's Avatar
How well does that pump handle "sucking" instead of pushing? I've heard external pumps don't really like that, but it's fine then that's a great system!
Old Feb 4, 2005 | 01:05 PM
Speed Engineering's Avatar
Former Vendor
The trucks we have installed the holley pumps on, we just used the factory bucket. Our customers have been driving them for about 6 months now without any problems. We leave the rubber baffle on it so fuel wont come rushing out when under heavy acceleration or braking. We do the same with our large fuel system. We had our large fuel system down to an 1/8 of a tank and was not sucking any air. You just have to be careful not to suck the small bucket dry under acceleration and low fuel levels.
The tube 90* bend out of the tank will not fit under the bed of a stock truck. We had it under a truck with a body lift. For stock trucks we send a direct 90* bend without any tube. It will cut down on the fuel flow a little, but it is nessary for trucks with out body lifts.
As far as sucking. So far we havent run into any problems. We have used this setup on about 3 trucks so far. The only dissadvantage to it is the return regulator is a direct flow back to the tank. So every time you start it up. The key must be cycled on for a sec to pump pressure to the rail again. All the F-body kits like this do the same thing though. Some people dont mind it others get annoyed by it.
Sean
Old Feb 4, 2005 | 04:53 PM
Formerly one92rs
Talking
cool that is what i wanted to know. as long as the little less flow is still more than stock. really the only time i need more is when on the button anyway. thanks,now i need to scrounge up some cash.
jdb11386
Dec 3, 2015 09:34 PM
wrb002
Aug 31, 2015 12:00 PM
black6spdz
Jul 16, 2015 01:32 AM
4B11T
Jul 13, 2015 03:48 PM
Deceptarado
Jul 8, 2015 05:24 PM
