neeed some info on swap for towing...
Old Jan 3, 2012 | 12:18 PM
BrandonAtkinsonRacing's Avatar
Registered User
Default neeed some info on swap for towing...
I have an 05 z71 gmc with a 5.3. she is major weak now and i want to upgrade to 6.0. Been doing some reading on the forum here. Is there a particular model 6.0 i would want for towing and as far as a reprogram can i reprogram with something like a cortex programmer or do i have to look otherwise? Everything else seems to be plug and play as far as the install? Thanks in advance!
Wayne
Old Jan 3, 2012 | 12:44 PM
Registered User
I plan on ordering a new gm crate motor is the plan just wanna make sure I get what's best for towing. lq4,lq9? maybe a good bolt on exhaust or headers? Not looking to do anything internal on motor just replace motor and some add ons. Thanks again!
Old Jan 3, 2012 | 03:32 PM
Coban's Avatar
Get an LQ9.
Plug and Play install.
Get a custom tune, no programmer crap.
Headers and cat-back if you want a little more power and a lot more noise. (seriously)
Enjoy.
Get 4.10 gears if you need more towing power.
Old Jan 3, 2012 | 03:37 PM
Registered User
Originally Posted by Coban
Get an LQ9.
Enjoy.
Thanks! Yea im not sure of the exhust i like my quiet ride haha. BUT a nice exhaust system that may be abit quieter than the average performance exhaust would not be out of the question!
Old Jan 6, 2012 | 04:48 PM
02'Z71ONDUBZ''s Avatar
I wouldn't buy a new crate motor unless money isn't an object... I never have priced them but would be scared to. You can pick up a used long block for anywhere from 700-1500, depending on yr and whether its a LQ4 or LQ9. Main difference between the two is flat top pistons on the LQ9 bumping up compression for a little extra power but not alot. I would look for an 05+ LQ4 long block with around 60k or less, take the money you save over an LQ9 or crate motor and buy a cold air intake, set of stainless headers and y pipe off ebay, and a corsa touring exhaust to keep things fairly quiet. Then take the truck and have it custom tuned by a good tuner, or get a pcm custom tuned by a board sponsor and mailed to you. Would run very well and be much more reasonable price wise. If you really want a significant increase in power, you should stick a cam and set of springs in it while you have the engine on a stand.
Bumpers
Aug 4, 2024 09:44 PM
Bluecollar Hotrods
Jun 11, 2024 11:37 PM
OHsixLS3
Aug 10, 2015 07:19 PM
05GMC4.8
Aug 7, 2015 09:55 PM
gtyler04
Jul 28, 2015 06:21 PM
