Needing help on a tbss intake
Old Jul 14, 2015 | 11:30 PM
04450r's Avatar
Registered User
Default Needing help on a tbss intake
Bought a tbss intake for my 03 silverado 5.3 and was wanting to no how the fuel rails will hook up or which ones I need to buy so I can hook them up
Old Jul 16, 2015 | 08:22 AM
porksoda's Avatar
Use either your factory rails with modified crossover and mounting, or use the TBSS rails with modified return line using either a regulator or Corvette fuel filter. Either one benefits from a tune but using the TBSS rails will require a tune because it is not using a vacuum regulator anymore.
Old Jul 16, 2015 | 11:31 AM
04450r's Avatar
Registered User
Finally someone helped thought no one was. But I was Going to go with the fast Fuel rail and didn't no what to buy
Old Jul 16, 2015 | 01:11 PM
porksoda's Avatar
I just did my swap a week ago on my 03. I used the TBSS rails so I'm not familiar with the Fast rails or what they need. Everything else about the swap though is still fresh in my head.
Old Jul 16, 2015 | 04:02 PM
04450r's Avatar
Registered User
See I was going to go with just use the stock rails but they look like carp. I sent my intake off to get shaved and cleaned up instead of the own look. Another reason to leave the stock rails
Old Jul 17, 2015 | 10:08 AM
porksoda's Avatar
This is what I did
Old Jul 17, 2015 | 04:59 PM
04450r's Avatar
Registered User
Who shaved the intake for u
Old Jul 18, 2015 | 09:11 AM
MrHorsepowerLSx's Avatar
11 Second Club
I have the tbss intake on my 00 silvy, I swapped over to AN line and fittings, and corvette filter/regulator (waste of money imo) I would leave stock filter and use a regulator for the return/pressure. But you don't need a tune for the new intake as the FPR on the old intake uses engine vacuum. I also have a stealth 340 pump in the tank as we speak. But the intake alone will not rip off your pants you need more supporting mods to make it worth while
Old Jul 20, 2015 | 10:01 AM
04450r's Avatar
Registered User
O I'm not running it on a stock motor is going to have enough mods to tell a difference. But did yeah have any trouble modified the brackets to make the aftermarket rails work right.
Old Jul 20, 2015 | 10:27 AM
11 Second Club
Nope I used the factory tbss rails.... I'm getting ready to swap over to FAST rails whenever my truck comes back from paint. But you can get rails for the factory manifolds I believe
