Need Wiring help
Old Apr 30, 2009 | 03:21 AM
Spoolin's Avatar
GFYS and STFU
Default Need Wiring help
I'm pulling off my Dr. X and 90mm TB tonight and replacing it with the OEM stock 78mm TB and I have extra wires!
Plug into the TB has 7 wires and the wiring harness has 8. Where does the extra one go? It's the pink one! (figures )
Can someone take a picture of their harness or plug to see if there is 7 or 8 wires going into their TB?? Thanks!
Take your time fellas, I'm just sitting on a stool in my garage until I figure it out!
Until then I'm (**** I'll never figure it out if I keep drinking!
Old Apr 30, 2009 | 05:59 AM
Tootall's Avatar
remove the Dr X harness . . . just use the stock connections
Old Apr 30, 2009 | 12:09 PM
Spoolin's Avatar
GFYS and STFU
I think I figured it out...the pigtail that I have that plugs into the TB only has 7 wires made up. When there should be 8 going into it. I have to re-pin the pigtail.
Old Apr 30, 2009 | 12:13 PM
Wilde Racing's Avatar
How do I change this text
I'd send the pigtail back, hope you didnt pay too much for it.
Old Apr 30, 2009 | 12:24 PM
Spoolin's Avatar
GFYS and STFU
I know right!!!
You should of seen me try to solder the wires without that handy solder base/kit/stand/thingy that you have!! I'm a mess right now but loving it!! btw you'll be getting something in the mail but it isn't what you think.
Old Apr 30, 2009 | 05:11 PM
Btw, the one pin that was missing, I stole to get you going when you were here! So you have all the pins, just need to pull the pink long wire out of the 90mm plug
Old Apr 30, 2009 | 05:44 PM
Spoolin's Avatar
GFYS and STFU
I got the plug re-pinned and the truck is back up and running! No more Reduced Engine Power mode for me!
It looks professional too!! I think I might of learned one or two million tricks from you oh master!!
I also have....FANS!!!! Woohooooo
Thanks again Dusty!!!
00loudchevy
Dec 3, 2015 05:54 PM
bearden86
26
Nov 15, 2015 03:58 PM
JordanH
Oct 3, 2015 03:59 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
Wrecker 426
Sep 30, 2015 09:39 PM
