need sum cam suggestions.
Old Apr 22, 2010 | 01:51 PM
Zeppo's Avatar
From: Muldrow, OK - a.k.a. Smelly Crack of the Earth
Default need sum cam suggestions.
k got a 07 silverado classic with a 4.8. so far ive done 4.10 gears, trutrack posi, shortys, cold air intake, dual exhaust (no cats, x-pipe, two 50 series flows). looking to do a cam next. need sum suggestions on how big i can go. ive heard if i go to big i can lose bottom end, wich obviously i don't want to do. what would be a decent sized cam that wouldn't lose bottom end but still add a pretty noticible change?
Old Apr 22, 2010 | 03:11 PM
brent5631's Avatar
212/218 is a pretty proven cam. In a 4.8 it would probably still need a stall to be the best.
Old Apr 22, 2010 | 07:57 PM
03CHEVYBOY's Avatar
Tr224 cam with a 3600 stall should be good, look at circle-d or speed-eng's website. The stall with your 4.10's will out help with your bottom end. Some tranny work should be seen in the future if you want to run it hard. Im in the process of getting a stall, as for the 6 speed tranny anything from tremec that fits will definatly do as long as you dont plan on towing or hauling a lot.
Old Apr 22, 2010 | 08:33 PM
budhayes3's Avatar
PT's Slowest Truck
Is the truck a daily driver or a track queen? TR224 is a little big for a daily driven 4.8 IMO, but opinions vary. Search 212/218 and you'll find a wealth of info on a well known proven street cam. Match a torque converter to the cam you choose...If you search "4.8 cam", you'll probably find a bunch of different combos that guys have used with great results. Personally I wouldn't go over 220 in duration in a 4.8 that sees street use, but that's just me
Old Apr 22, 2010 | 10:27 PM
jg53's Avatar
well put!!!^^
Old Apr 23, 2010 | 01:58 AM
05gmcsierra's Avatar
i say 212/218 cam would b a good cam on a 2600-2800 stall... i have it on my 5.3 with no stall and it has a good gain of power all around...its got low end torque as well as high... for a 4.8 i would b great... and yea if u go bigger then a tr220 u will need a 3600 stall and is that what ur looking for? i mean its all on what u want..
Old Apr 23, 2010 | 04:33 PM
Zeppo's Avatar
DONE A BIT OF RESEARCH AND I THINK THIS ONE WITH A 2500 STALL WOULD BE NICE. WHAT DO YOU GUYS THINK. Comp Cams Cam Style Hydraulic roller tappet
Basic Operating RPM Range 800-5,200
Intake Duration at 050 inch Lift 212
Exhaust Duration at 050 inch Lift 216
Duration at 050 inch Lift 212 int./216 exh.
Advertised Intake Duration 266
Advertised Exhaust Duration 270
Advertised Duration 266 int./270 exh.
Intake Valve Lift with Factory Rocker Arm Ratio 0.520 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio 0.524 in.
Valve Lift with Factory Rocker Arm Ratio 0.520 int./0.524 exh. lift
Lobe Separation (degrees) 115
Intake Valve Lash 0.000 in.
Exhaust Valve Lash 0.000 in.
Computer-Controlled Compatible Yes
Old Apr 23, 2010 | 05:42 PM
Beatdown Z's Avatar
Laid Back
Has anyone tried this cam yet? Looks to me like it would perform pretty good in a truck...
HT1 SDPC LSX Truck Cam 214/218 .555/.562 111
http://sdparts.com/details/scoggin-d...er/cc54-st1-11
Old Apr 23, 2010 | 10:53 PM
budhayes3's Avatar
PT's Slowest Truck
Both of those cams look very interesting...intriguing how they went different directions with the LSA's...
Old Apr 23, 2010 | 11:18 PM
GMCtrk's Avatar
You can definitely lose bottom end if you go too big. I have a 222/226 in a 6.0 and it's definitely softer below 2000 rpms than the stock cam. But it's not like I'm hurting for torque or anything, the 4.8 would be a different story. I really like that 214/218 cam.
2500ZL1
Jan 25, 2016 06:30 AM
lawhitediamante
Aug 12, 2015 12:14 PM
steves86ta
Jul 28, 2015 10:21 AM
WICK3DxGATA
Jul 21, 2015 06:59 PM
projectnightcrawler
Jul 19, 2015 11:30 PM
