Need some wiring help
Old Aug 18, 2003 | 11:27 AM
ranwalk's Avatar
Default Need some wiring help
Ok...When I get the water/alky injection kit I'm sure I will need to tie into a 12v ignition on source. Do you guys have any suggestions on a good place to tie into for this.I dont want to overload a frequently used circuit.
Thanks,
Randy
Old Aug 18, 2003 | 03:04 PM
454SuperSport's Avatar
Default Re: Need some wiring help
when i installed my e-fans i tapped into the ignition-hot wire in the whipple wiring harness. so far it has worked fine
Old Aug 18, 2003 | 09:40 PM
BigKID's Avatar
Look in your underhood fuse panel, you should have some empty circuits you can use such as 4x4 and stuff like that.
00loudchevy
Dec 3, 2015 05:54 PM
bearden86
26
Nov 15, 2015 03:58 PM
JordanH
Oct 3, 2015 03:59 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
Wrecker 426
Sep 30, 2015 09:39 PM
