need some opinions....
Old Apr 8, 2007 | 07:23 PM
Wide Open's Avatar
5.3L = 3.78 bore
3.78^2 * 4.00 stroke = 359 ci.
Old Apr 8, 2007 | 07:37 PM
blake2kz71's Avatar
im a little confused here, wouldnt it be bored to exactly a 5.7 bore? then buy the stroker kit or individual parts to make it a 383?
Old Apr 8, 2007 | 07:46 PM
blake2kz71's Avatar
been doing more research: looks like the truck intake aint gona cut it. Il probaly get the vic jr with the elbow and all. for the cost, will the 317 heads work well?
Im kinda trying to get me a parts list and buying stuff when i can.
Old Apr 8, 2007 | 07:55 PM
Wide Open's Avatar
If you mean boring a 5.3 block to meet the 3.90 bore of the 5.7 LS1 I don't think that is possible. Normally a maximum overbore is .060 which would put you at a bore size of 3.84. That bore with a 4.00" stroke will get you 371 cubes.
Using an LS1 block will get you 382 ci with a 4" stroke.
Old Apr 8, 2007 | 08:01 PM
blake2kz71's Avatar
its been done, safely. When its done i can buy all the stroker conversion parts that are made for the ls1 bore. maximum overbore is .06??? how long you been around engines? lol
Old Apr 8, 2007 | 08:04 PM
nightrunner's Avatar
Mr. Obvious
there have been several that have made a forged 5.7L iron block (5.3 bored to 5.7 bore size)
read on tech and they will tell you a 383 is a ls1 with a 4" stroke crank, but a 382 is a resleeved ls1 with a very large bore(not sure what it is cuz i wouldnt want one) with the stock stroke
i couldnt find a spec on the stock ls1 bore but found a 383 shortblock that TSP had a single surplus of in a FS thread andit listed it as a 3.90" bore x 4.00" stroke
Old Apr 8, 2007 | 08:43 PM
blake2kz71's Avatar
yeh im just trying to get all the exact specs of the 5.3 and 5.7 so i can let my guy know thats doin the block work.
Old Apr 8, 2007 | 09:18 PM
Wide Open's Avatar
I was only trying to be helpful with your question. If a 5.3L block can be bored one hundred and twenty thousandths (.120) over to simulate a 5.7L then go for it.
If you don’t know what .060 over bore (sixty thousandths) is then I guess I have been around engines longer than you.
Bottom line...it's simple math -
0.7853982*3.90*3.90*4.00*8=382.269011904 cubic inches.
Call it a 383 if you wish.
Old Apr 8, 2007 | 09:21 PM
Mr. Obvious
it is border line and i read on tech and on place will say a 4" stroke in a ls1 will equal 382 some say 383
Old Apr 8, 2007 | 09:25 PM
blake2kz71's Avatar
i appreciate the help but all i was saying is im not just coming up with a new idea. i did some research and there are a few guys that have done without problems. I do know what .060 is I am a machinist. I understand the math I though you were saying it couldnt be bored more than .060 over. I found a deal on a 5.3 block and i read a long time ago about it so i said hey i can do that too. Also I can buy all off-shelf parts. What else can you do better with a 5.3 block?
