Need some help with fuel pump
Old May 22, 2008 | 11:16 PM
Jhops's Avatar
Default Need some help with fuel pump
Me and Viclama03 have been dropping my truck and when we went to put the tank back in those two of those round plastic things broke off. Vic has another pump but it has the pump itself is bad, we were wondering if theres anyway to use my actual pump but the use the top part from the other one. We started taking it apart but couldnt get that round plastic tube off. Is there any way to fix this? Or are we stuck with buying a new one?
Old May 22, 2008 | 11:40 PM
Stoichiometric's Avatar
If you are trying to remove the fuel feed tube coming out of the pump use a heat gun. Heat it just enough to make the plastic line soft enough to pull off. You will need to use a clamp when you re-install it.
Old May 23, 2008 | 06:38 PM
DrX's Avatar
DrX
You mean the fuel line retainer clip? Try Auto Value or Napa.
http://fmsiinc.com/fuel-retainer-clips.htm
ss4chad
Aug 15, 2015 02:25 AM
05GMC4.8
Aug 7, 2015 09:55 PM
MS3Z
Jul 30, 2015 06:17 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
