Need more top end what can i do
Old Apr 10, 2005 | 10:19 PM
MR.QUIK's Avatar
truck is just used 4 racing
Old Apr 10, 2005 | 10:28 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
IMO the x-pipe is worth the money since you have the exhaust maybe some better mufflers like the ones that i recommended get an intake and a cam with the cam you will need a stall to make up for the lack of bottom end power but that will definately help.
Old Apr 10, 2005 | 10:31 PM
MR.QUIK's Avatar
running 3500 stall what kind of intake
Old Apr 10, 2005 | 10:35 PM
BlueSS's Avatar
joe joe you wanna go faster on your pick up just drop the motor from your nova in there that'll get you moving quicker...
Old Apr 10, 2005 | 10:37 PM
1slow01Z71's Avatar
I got an airaid mit and an ebay intake with a k&n conical saved a couple hundred in the process and only lost a couple of horsepower to other expensive intakes. The cam would be the next step if you are looking for top end. The intake alone is not going to give you that big a difference.
Old Apr 10, 2005 | 10:38 PM
MR.QUIK's Avatar
ya no **** ill need 2 do it 2 run with that supera 11.95 damm thats fast
Old Apr 10, 2005 | 10:42 PM
BlueSS's Avatar
what size of cam could he install? doesn't the charger run more efficient with stock compression? how much gain could he get off a cam?
Old Apr 10, 2005 | 10:44 PM
F8L Z71's Avatar
I think this guy gets charged for every word he types. You really should try to open up more man. 3 words replies are not very informative.
Old Apr 10, 2005 | 10:47 PM
1slow01Z71's Avatar
I would talk to Allen he could tell you what to go with alot better than I could.
Old Apr 10, 2005 | 10:50 PM
MR.QUIK's Avatar
running 6.0 liter with whipple 8 psi 3500 stall servo shift kit ASM long tubes no cats nelson tune 4.10 gears 29.5 m/t 80mm throttle body duel exahsat everything else is stock
