Need Intake Fuel Lines
Old Jul 12, 2010 | 06:49 PM
Bama2door's Avatar
Are these the correct fuel lines I need, I want to go ahead and place the order so they can get here ASAP
2x 658490
Old Jul 12, 2010 | 07:20 PM
A Low Dime's Avatar
13 Second Truck Club
Looks right to me. Not sure on how long of hose your set up needs, might work.
Old Jul 12, 2010 | 09:07 PM
Atomic's Avatar
I have a gauge for that
6" would be plenty
and bama2door is who I am helping if its not obvious
and cole, that was the last item on my list
Old Jul 12, 2010 | 09:14 PM
Bama2door's Avatar
Originally Posted by Atomic
6" would be plenty
Yea I know I was just making sure that the ends on those fuel lines were the right ones...
Old Jul 12, 2010 | 09:16 PM
Atomic's Avatar
yea, -6an which is 3/8", same size as the male part of the adapter fittings. placed the order yet?
Old Jul 13, 2010 | 04:12 PM
nickleahy23's Avatar
well damn thats saying something
Are the fittings on the fuel rails removable?
ya its the same set up as stock...i could snap a picture if you wanted, but it sounds like your going the professional route lol...i just needed something quick and cheap
Old Jul 13, 2010 | 07:31 PM
fastnblu's Avatar
Originally Posted by A Low Dime
You can get the fittings from summit. 14mm blah blah on one end with 6an on the other, then a length of line, next fitting is -6an on one end to quick connect. Same thing for the feed line,m just a 16mm blah blah instead.
Blah blah = the rest of the name i cant remember.
http://www.summitracing.com/parts/EAR-9894DBHERL/
http://www.summitracing.com/parts/EAR-9894DBJERL/
^^One of those will adapt the return, the other will adapt the feed to -6an
Basically just find how long of section of AN hose you need, then add those to one end, quick connects to the other. One disconnect is 3/8, the other 5/16
http://www.summitracing.com/parts/RUS-640860/
http://www.summitracing.com/parts/RUS-640850/
LowDime, I never knew those existed til I found them back when I needed fittings for my tranny back in May. Slick for sure.
Atomic, I'm shocked S&P has gotten it wrong 2x. But then again, they sold me a AC compressor for a Vette w/. a different ribbed pulley than I needed. While I needed the Vette stuff for that swap, I didn't need it to be 1 rib off. I couldn't figure out why I was shredding belts left & right til it was figured out.
So, I never got to see if the AC worked on that truck. Maybe 1 day.
Originally Posted by nickleahy23
just go to your local napa or a store like it..they will make you the piece of hose you need right there..they have the fittings that clip onto the nbs fuel rail, where the flex line is stock...they put those fittings on some fuel line plastic hose, and then you do a compression fitting on the other end. cut off the old fuel lines and connect them...i just did this on my tahoe and it works just fine...had them on for a month and no issues...only cost like 35 bucks
I'd still like to see pics. A low cost alternativer is sometimes a better option. I had to get stuff welded to go from my LT1 lines to my AN, & they wouldn't guarantee if it'd leak. Ah, hello, gas lines?!? Since then, not for that reason tho, I don't care to do business w/. them.
Old Jul 13, 2010 | 11:11 PM
ill take some pics tomorrow...
the napa had the fittings just like stock, but with a barb on the other end...they had plastic fuel line, rated at high psi and made to withstand the fuel corrosiveness...put the fitting in some type of clamping gun, stuck the hose in the other end and crimped it on..one side done...other side just bought a compression fitting and put one end on the plastic hose and the other on the metal fuel line that i hack sawed off...snugged the compression fitting up and done...no issues and a quarter of the cost...the most expensive part was the plastic fuel line at 4.99 a foot
Old Jul 13, 2010 | 11:28 PM
A Low Dime's Avatar
Ive seen those in there before but never thought to use those. I never really see a Napa and they close so early.
5.3Okasai
Mar 9, 2022 01:07 PM
chopperloco
Jul 10, 2016 10:45 PM
MWRitter
Jul 27, 2015 09:41 AM
76k10chase
Jul 17, 2015 01:48 PM
Nimoryan
Jul 5, 2015 03:50 PM
