Need help w/ 5.7L vortech cam
Old May 6, 2003 | 10:37 AM
TNT-SS's Avatar
Default Need help w/ 5.7L vortech cam
Can anyone help me with finding a good 5.7l cam or how to do a LT4 hot cam!
Old May 6, 2003 | 07:21 PM
L82gofast's Avatar
Default Re: Need help w/ 5.7L vortech cam
Are you asking about the L31 5.7 engines in the 96 to 98 trucks?
Old May 7, 2003 | 11:55 AM
Pro Stock John's Avatar
Registered User
Yeah I think he is talking about the L31/5.7 iron block.
I have the same motor in my 99 Tahoe.
I read how a guy did a hotcam in his p/u and lost a lot of bottom end torque.
I think that's it's probably not a good idea to go with a big split like the hotcam.
IMO I would go with like a 216/216/114, if you go too big the truck might not be good for towing... Anyone else?
Old May 7, 2003 | 06:03 PM
L82gofast's Avatar
Ok, I had a L31 in my '98. You are limited in lift by the heads. I installed a comp XR258R in mine. It is a 206in 212exh with a 480 488 lift. I changed the springs as well of course. I did not loose any low end with this cam but gained big time on top, over 3500rpm. No numbers, it just pulled much more than with the stocker.
I would recommend it if you don't want to pull the heads and have the spring seats and valve guides machined for a higher lift.
Mike
lawhitediamante
Aug 12, 2015 12:14 PM
sauldgold
Jul 23, 2015 02:15 PM
4B11T
Jul 13, 2015 03:48 PM
FlowmasterMufflers
Jul 9, 2015 11:35 AM
