Need Help (valvetrain Noise) Pass. Side
Old Mar 19, 2007 | 04:15 PM
adrenalinep's Avatar
Default Need Help (valvetrain Noise) Pass. Side
I had a ticking from passenger side. I pulled the valve cover and found a bent pushrod. I replaced it on Sat. and now seems to have gotten louder. I double checked the rockerarms for play and every thing seems to be fine. Could it possibly be a lifter. Its always something with this truckif not the trannny its the engine
Old Mar 19, 2007 | 04:58 PM
fyi, I have the ls6 cam and springs and stock pushrods
Old Mar 19, 2007 | 06:22 PM
98TAauto's Avatar
bent valve?
did you tq the rocker arms again to make sure none had backed out? I had one almost fall off after I did my cam swap. Even with locktite and tq'ed to specs it backed out. I picked up a loud ticking and pulled the cover to find the rocker was VERY loose. Luckly no damage was done
wish I could help more but re tq them to specs and if it doesnt go away, then its a valve or lifter
Old Mar 19, 2007 | 08:02 PM
thanks for reply , I just pulled the covers and double checked every thing again. I was hoping it was the rockers but im afraid your right . Its gonna be the lifters or a bent valve.
Old Mar 20, 2007 | 08:09 AM
98TAauto's Avatar
ouch.... well you know what that means
order some heads and slap on why they are off
Old Mar 20, 2007 | 08:10 AM
98TAauto's Avatar
btw, best of luck.. if this stuff was easy and simple it wouldnt be fun would it HAHAHAHAH
Old Mar 20, 2007 | 09:09 AM
Tootall's Avatar
are you sure that it's not another bent rod?
Old Mar 20, 2007 | 08:48 PM
ap2002's Avatar
time to upgrade to a 6.0...
SlvrSierra4.8
Oct 1, 2015 09:39 PM
97aztecgt
Sep 10, 2015 05:07 PM
madmann26
Sep 7, 2015 06:41 PM
xerox17
Sep 5, 2015 01:23 PM
