Need help with Plastigage and rod bearings!!
Old Dec 29, 2003 | 07:41 PM
ranwalk's Avatar
Default Need help with Plastigage and rod bearings!!
I've never used plastigage so bear with me. I got them to get me some at work so I could do it tonight. I think they got me the wrong size??
I got my bearing specs from my friend at a Cadillac dealer. He said it shows clearance to be from .025-.076mm. The plastigage I have is blue-it says on the package use blue for .102-.229mm
Then it says use red for .051-.152mm
I'm thinking I need the red??
Old Dec 29, 2003 | 09:15 PM
12 Second Club
ya u need the red. and when u do it, lay the plastigauge diagonally across the crank.
Old Dec 31, 2003 | 12:08 AM
gonzo 6.2's Avatar
I think you need green.Plastigauge isnt super accurate but close enough
.0015-.003 thou of an inch would be fine.
Old Dec 31, 2003 | 08:35 AM
12 Second Club
dont forget we are in metric and not standard measure...
Old Dec 31, 2003 | 08:44 AM
Reckless's Avatar
Still moddin'
I always use the green one and shoot for .002" to .003" on the rod and mains. Not sure about that metric stuff And remember, use the plastigauge with the bearings and everything dry (no lube)! Lube will alter the measurements. I have also found that plastigauge tends to err on the low side, that is readings a little tighter than with a micrometer, so don't worry if they show a little "tight".
Old Dec 31, 2003 | 04:47 PM
10 Second Club
I have used the red stuff in the past for rod and main bearings.
cheyenne383
Nov 13, 2015 09:24 AM
lukn4trbl355
Oct 21, 2015 11:19 PM
sTNT971
Sep 26, 2015 04:22 PM
97_ek
Sep 23, 2015 09:16 PM
