Need help with a misfire problem
Old Feb 4, 2004 | 06:05 PM
25thhawk's Avatar
Default Need help with a misfire problem
My truck is misfiring in cyl #4. It randomly fires maybe 50% of the time better at half throttle, extremely bad at 1/4 throttle. Only on cyl #4. It has been doing it for a while so I replaced all plugs and wires. Didn't help, so I replaced the #4 coil, this didn't help either. Any thoughts? It is a 2000 5.3 silverado. Thanks
Ryan
Old Feb 4, 2004 | 08:01 PM
GREGGO's Avatar
Burning oil? How did the plug look when you took it out compared to the rest? What other mods do you have? Ever run nitrous?
Old Feb 4, 2004 | 08:04 PM
#4 injector could be clogged up?
Old Feb 4, 2004 | 08:05 PM
25thhawk's Avatar
no stock work truck, about 60000 miles, no mods, plug was wet and black, it definitely wasn't firing
My problem is definitely not with the injector plug or wire
I have tried multiple wires and coils, I definitely have a wiring or computer problem. But nothing has ever been apart and is all stock.
Thanks
Old Feb 4, 2004 | 08:06 PM
25thhawk's Avatar
Definitely getting gas. Thanks
Old Feb 4, 2004 | 09:35 PM
Texas Terminator's Avatar
11 Second Club
injector stuck open? might try swapping it to another cylinder and see if it follows. driver for that cylinders injector/coil failing? does it do it when it warms up or no particular time?
Old Feb 4, 2004 | 09:52 PM
25thhawk's Avatar
Does it all the time.
Would a stuck injector cause a coil not to fire? I mean I used a timing light on the wire and there is not spark about 50% of the time.
Thanks
madmann26
Apr 29, 2020 09:17 AM
bearden86
26
Nov 15, 2015 03:58 PM
dsbodley
Nov 14, 2015 09:46 PM
2002_Z28_Six_Speed
Oct 4, 2015 01:34 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
