Need help with hurst roll control
Old Sep 19, 2004 | 11:06 AM
Dark Halo's Avatar
Default Need help with hurst roll control
I got my hurst roll control in and Have no idea what to do. Has any of you installed one on your truck? Also What parts do I need for the install? I can't tell where I will need to run the lines at? Will I be runing the line to the ABS controler? Any help would be great thanks
Old Sep 19, 2004 | 11:49 AM
Default roll control
Dang it's been so long since i did the one on my Z, um.... i know on my camaro you used the line that fed the front brakes, there is one line that goes into the block for fron, and one for rear, you disconnect the front in line, run that to the line lock, then out of the line lock into the front in on the block, that way it holds pressure to the front brakes when the solenoid is engaged.
Old Sep 19, 2004 | 10:20 PM
Dark Halo's Avatar
on your F body the ABS box is under the hood right? I know mine is under the truck attached to the frame
Old Sep 20, 2004 | 02:28 AM
Default yup
Yup, i climbed under my truck today, and the abs stuff is mounted to the frame under drivers seat. Easily accesible, PITA to work upside down on your back, but at least no need for a hoist.
SloSVO
Nov 22, 2020 07:34 PM
Avalanche2002
Nov 30, 2015 07:31 AM
2002_Z28_Six_Speed
Oct 4, 2015 01:34 PM
