Need help fast
Old Jul 23, 2005 | 11:03 PM
vanillagorilla's Avatar
I've never had that happen. By the time my slow *** gets the old cam out, and the new one in, the lifters have already bled down.
I'm still confused though. The force from tightening the bolts will push the oil out of them. If your lifters are that stiff, then I would change them.
Old Jul 23, 2005 | 11:04 PM
BlownChevy's Avatar
blownerator
25 Year Member
yeah I am a bit worried too...how many miles?
Old Jul 23, 2005 | 11:09 PM
Well the lifters sat over night with no presure on them. We put the rockers back on,tighend them down, saw that the valves were opening up, Said well ****!, scratched our heads, went to take them back loose and noticed that the rockers came up from the push rod side only. So the valves were shut... And now we tightend them all up (not torqued) and let them sit for a few (beer break) and see if they all do the same.
Old Jul 23, 2005 | 11:11 PM
65,5xx
Old Jul 24, 2005 | 12:00 AM
What did you torque them to? Did you rotate the engine several times to check everything? What are you using for oil 80W-120?
Old Jul 24, 2005 | 04:19 AM
Ok guys heres the update, The truck is all put back together and runs fine. Sounds ALOT like a sewingmachine. Only problem is that it has barley any oil preasure at idle, Tached up it has around 40-50 pounds at 1500-2000rpm. My best guess is that The little o-ring in the pump is shot. Its the only thing that we forgot about. The vaulve problem is fixed so far, it was just a fast omg type of thing that we jump to conclusion about. The rockers are torqued to 30 nm I bilieve, What ever gm says. Is there any chance that a place like Advance Auto would have one of the oil pump seals you guys think? If not it will be tuesday before I can get the part from gm. Also I'm useing Gastrol 10w-40. So who is with me on the oil pump seal for no oil presure at idle. Thanx for the help tonight guys! But Its 4:30 and I'm going to bed.
Old Jul 24, 2005 | 10:44 AM
Come on guys I know some one has had a problem like this before?
murderedSS
27
Oct 12, 2015 11:13 AM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
sTNT971
Sep 26, 2015 06:27 AM
whitelazer
Sep 22, 2015 09:38 PM
