Need help ASAP!! longtube headers
#26
Well trucks back to running like ****... It ran beautifully for a few days then all of a sudden it went back into its old habits missing spitting and puffin black smoke. I'm starting to get pissed off. I start school in a few days and I need the truck to be running problem free. The truck is throwing out a p0300 code again, no idea why this time, all the wires aren't touching anything and has the right spark plugs. Wtf is going on!
#27
Pull a wire one at a time and see if each cylinder is hitting or not
#28
Did you have any tuning adjustments made? If not, and I doubt you did, then I'd almost guarantee thats the problem. As others have said you need to get a tune for the headers that will remove the rear O2 sensors.
The random misfire means its not limited to one cylinder. Is it possible you melted an O2 wire on the headers? That has happened to me before... that will cause some issues exactly like this.
#30
I think last post is thinking u removed your cats and would have to tune out rear sensors. But if your running cats that work then sounds like the rear o2 sensors might be bad and worth replacing to see if it helps
