Need Help/Advice on installing injectors
Old Jul 29, 2003 | 10:32 AM
ranwalk's Avatar
Default Need Help/Advice on installing injectors
I just recently purchased a set of 8.1 liter injectors from one of our board members.Should have them by end of the week.What will I need in order to do the install? And What all is involved in doing it? I have the whipple charger,Will it have to be removed to gain access?
Thanks for any input,
Randy
Old Jul 29, 2003 | 11:16 AM
BigKID's Avatar
Default Re: Need Help/Advice on installing injectors
Dosnt pertain to the physical install, but have you alread spoken with Diablo about changing your tune? Are you axeing the supplimental Whipple injectors and computer?
Old Jul 29, 2003 | 11:39 AM
ranwalk's Avatar
James at RWTD is currently working on a new tune for me. I will be running the 2 whipple injectors also.Probably need them with what I'm trying to do.The tune is going to be set up for the 8.1 injectors and 8 pounds of boost.I've got an smc water/alky injection kit on the way along with some LT1 fans from bigtex(to make room for the water/alky jug).
Old Jul 29, 2003 | 05:25 PM
blacksheep's Avatar
8 psi? Go ahead and go 9-10psi. I ran at least 8 psi ever day when I had my Whipple, just make sure the crank pulley is not coming off.
Old Jul 29, 2003 | 05:42 PM
ranwalk's Avatar
Hey Curt,
I might go 9-10, but I allready have the 8 pound pulley,so I'm going to try that first.If I have good luck/results with it, then I might up the boost some more
Old Jul 30, 2003 | 10:43 AM
ranwalk's Avatar
TTT....come on guys,a little help please.I dont want to screw anything up.
MS3Z
Jul 30, 2015 06:17 PM
Slammed96
Jul 27, 2015 07:22 AM
lxcoupe
Jul 21, 2015 02:12 AM
