need cheap posi, spool
Old Nov 8, 2004 | 03:11 PM
bigbody's Avatar
Default need cheap posi, spool
My friend has a 91 scsb chevy, with a 383 stroker an just a bunch of other stuff to. But he is only running his truck at the track, its not a daily driver. So there for he wants a full posi. An he is trying to find a spool for his truck. Im not sure if there called a spool or not but does anyone know what im talking about? It fits inside your locker an makes any rearend a full posi by locking the axles. Is this right or not. If so does anyone know where he could find one for his truck at. He just has a GM factory 10 bolt rear end right now.
An what gears do you think he should put in it? He has a 3:08 right now but he wants at least 3:73s or 4:10s, what do yall recomend?
Old Nov 8, 2004 | 03:26 PM
Yelo's Avatar
you can weld the spider gears together.....it's the cheapest spool you can buy, but if you do ANY driving on the street you WILL bind up the rear-end around corners and break stuff. I ran a welded-rear for about 6 months at the track on a '69 Nova with a bored/stroked 400 making over 550hp, I even drove it to the track home a few times when the guy that owned the trailer I used needed to use it himself
This is certainly not the best or even a recommended way to add positraction to the rear of a vehicle....but it does work, alot of off-road guys do this because it IS cheaper that air-lockers or full-spools
Old Nov 8, 2004 | 04:58 PM
bigbody's Avatar
yea he thought about that but he was not sure if it would break apart on him while he was driving it an cause accident
Old Nov 8, 2004 | 05:05 PM
Seeing Red Again's Avatar
If you weld it, just weld the spider gears together, but don't weld it to the case. This is where I made a mistake before, and wound up cracking the carrier because I was trying to weld cast (carrier) to forged (spider gears). Live and learn.
I would just drop a lock right in there for the time being. They are around $300 and install with simple hand tools. They are not the strongest option though, but it does meet your cheap qualification.
Old Nov 8, 2004 | 05:08 PM
Also, check with Randy's Ring and Pinion to see if they sell a mini spool for the 10 bolt. If someone makes one, Randy's sells it. I don't know which board sponsers might have one.
Old Nov 8, 2004 | 06:21 PM
bigbody's Avatar
OK then I guess I will try looking into randys an some of our sponsors, Thanks
JordanH
Nov 6, 2015 07:42 PM
turbo6c3
Oct 5, 2015 06:11 PM
X_Racing1
Sep 30, 2015 01:59 AM
lsxperformance
Sep 14, 2015 10:53 AM
