Mystery coolant leak
Old Nov 27, 2005 | 08:25 PM
SaintLos's Avatar
Okay so can I be lazy and let this thing be for the timebeing or is it a timebomb?
Old Nov 28, 2005 | 01:19 AM
If its been doing it a while, it must be the gaskets, im sure they'll be fine till you get around to it. If it were the water pump, within a few weeks, maybe even a few days, the pump will eventually start pissing coolant out.
Old Nov 28, 2005 | 02:07 AM
TurboGibbs's Avatar
I know of 2 people that have had problems with the water pump gaskets seeping on their 5.3 Z71's. One buddy just keeps his system topped off about once a month.
Old Nov 28, 2005 | 07:26 AM
I've noticed mine leaking around the upper hose where it goes into the water pump. It's a pressed in hard line into the pump housing. anyone else seen this problem??
Old Nov 28, 2005 | 04:13 PM
smooth sierra's Avatar
I had this same problem a couple years ago. I simply put a little more 'snug' on the water pump bolts. While I wouldn't suggest just anyone doing this. I got approx 1/4 turn out of almost all the water pump bolts.
The leak has not been back since. If you do try it don't get carried away. as little as 1/8th of a turn can make a big difference. Maybe something to consider before tearing everything down, best of all it don't cost a thing.......provided you don't break a bolt off in the block
Old Dec 9, 2005 | 05:23 PM
well the dealership swapped out the water pump for a new one so we'll see how long it takes for this one to start leaking too.haha
bearden86
26
Nov 15, 2015 03:58 PM
03sierraslt
14
Oct 9, 2015 05:53 AM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
sTNT971
Sep 26, 2015 04:22 PM
