My pistons were flat.......
Old Mar 1, 2005 | 11:58 AM
Yelo's Avatar
hrm.....this is making the LQ4 and LQ9 less and less different
but it also has me worried about these LS1 heads I put on.....10.8:1 is ALOT higher than I was counting on, I'm not too sure I want to run 10.8:1 with 91 octane (that's ALL I can get in Cali/Nevada)
Old Mar 1, 2005 | 12:00 PM
BigTex's Avatar
Here is an 01+ 6L that I took apart a couple years back:
The dish is kinda hard to miss.
Old Mar 1, 2005 | 12:03 PM
JERRY2500's Avatar
14 Second Truck Club
Nope not mine, Flat no ridge.
Old Mar 1, 2005 | 12:04 PM
Yelo's Avatar
OK...that is NOT what mine looked like like.....
Old Mar 1, 2005 | 12:17 PM
BigTex's Avatar
Yelo - if its running well and not pinging under loads, I wouldn't worry about the compression. Worst case, a good tune will fix it up. With flat tops, you'll benefit from a tighter quench, which will fight off detonation.
LQ9 got revised pistons with coated skirt and stronger connecting rods.
LQ9 on left, 01 LQ4 on right
Old Mar 1, 2005 | 12:21 PM
Yelo's Avatar
Yeah.....it runs fine.....I'm gonna get it tuned next week to combat the idle and warm-start issues I'm having but otherwise it's fine.....
I was just suprised to see a flat-top piston in a non-HO 6.0...that would make it the same stock compression as the LQ9
Old Mar 1, 2005 | 12:23 PM
BigTex's Avatar
Thats assuming the chambers on the iron heads were the same size and the piston deck height is the same.
Old Mar 1, 2005 | 01:10 PM
Yelo's Avatar
True....they definitely come "out of the hole"...but by how much I didn't measure
Old Mar 1, 2005 | 02:51 PM
Those LQ9 pistons and rods look strong as hell.
Old Mar 1, 2005 | 06:13 PM
ktmrider's Avatar
Coulda swore the broken piston pics Parish posted on his original 6.0L showed the dish area like Richard posted.....
