My Nitrous is being installed!!!
Old May 14, 2005 | 11:06 AM
CAMMIN03''s Avatar
Banned
Default My Nitrous is being installed!!!
My nitrous is being installed right now... I cant wait..... Im thinking 35 shot... then jumping straight to a 100 shot.....
Its a wet kit....
What RPM should we set the window switch to??
My rev limiter is set at 6000 and 5950....
Should I so 3000-5900?
Also how much timing should I take out with my Ramcharger??
I was thinking 4 degrees for a 100 shot? is that right?
Old May 14, 2005 | 12:09 PM
redaddiction's Avatar
Don't start out at just a 35 shot you will never really be able to tell a difference.
I was running 27 or 28 degrees of timing on a 100 shot just always check to make sure you don't have knock.
Old May 14, 2005 | 12:34 PM
Deckhand's Avatar
do a 75 just to feel what it feels like.. not much..
then do a 100 and youll like it..
then do a 125 because youll like it even more..
then a 150 if you really want it to hit hard.. but 125 is a good balance.
Old May 14, 2005 | 12:43 PM
CAMMIN03''s Avatar
Banned
On a stock bottom end with stock fuel system!!!???!!!!
Old May 14, 2005 | 12:46 PM
I believe you can safely do a 125 shot safely not sure about 150.
Old May 14, 2005 | 02:35 PM
BeefTip's Avatar
From: Somewhere between Auburn, AL and Columbus, GA
Mat you sure do love punctuation don't you!!!!????!!!! Sorry I am in a weird mood right now from no sleep and a long hot day. I am ready to test out that system though. Since its a wet system, I imagine that 125 should be no prob on your stock fuel system, I think that the injectors limit more than the stock fuel pump.
Old May 14, 2005 | 05:53 PM
CAMMIN03''s Avatar
Banned
Does anyone have a picture of mounting the WOT switch..... Were thinking about just using a push button......
Old May 14, 2005 | 06:31 PM
98TAauto's Avatar
u dont need it.. just give me the juice
i'd say try a 75 first to be safe.. like said, i doubt you feel a 35.. you will know when the 75 hits though! I wouldnt push past a 100shot though depending on what kit you have?
Old May 14, 2005 | 10:00 PM
quicksilverado's Avatar
Hey Matt. You should take the truck over to Montgomery next weekend for the shootout. I'll be there and so will Cablebandit. He ran a new best at Silver Dollar last night. 10.17 @ 136
Old May 14, 2005 | 10:29 PM
CAMMIN03''s Avatar
Banned
Whew.... Thats awesome.....
Well the install is almost done.... All there is left to do is fill the bottle and connect all the hot wires to the battery... I will get some pictures up.... Carl and Lee @ lees performance center did a awesome job..... The switches and all...
