Is my exhaust system too restrictive for my 6.0L? :TECH ONLY:
Old Nov 6, 2008 | 05:41 PM
  #71
jakebdb56's Avatar
ah yea that's true, you still running the stock OS? I'm too lazy to look it up lol.
Old Nov 6, 2008 | 05:43 PM
  #72
hirdlej's Avatar
I'm just running my stock 4.8L OS but with cyl volume modified to accomodate the 6L
Old Nov 6, 2008 | 05:50 PM
  #73
RED04REGENCYRST's Avatar
same here.
Old Nov 6, 2008 | 06:21 PM
  #74
jakebdb56's Avatar
just curious, why'd you change the engine torque models under engine>torque management>engine torque?
Old Nov 6, 2008 | 06:24 PM
  #75
hirdlej's Avatar
I changed it from the 4.8L settings to the 6.0L settings.
Old Nov 6, 2008 | 06:28 PM
  #76
jakebdb56's Avatar
Where did you get the settings? I just compared it to a '04 Silverado SS 6.0 file and they're all different, i'm not trying to knitpick just trying to help you figure out what might be causing problems in the tune.
Old Nov 6, 2008 | 07:24 PM
  #77
hirdlej's Avatar
Wait, I was wrong. They're the same as the stock 4.8L 5 speed tune. I should change this BUT what would this have to do with cylinder airmass? Please learn me
File Type: hpt
Old Nov 7, 2008 | 11:52 AM
  #78
straightaxle's Avatar
Do you have a degree wheel? If so, you can still degree the cam, would be easy to do w/ the intake swap going on. Just get a piston stop to find true tdc, set up the wheel and put a dial indicator on the pushrod (but don't let it fight the valve spring, or it will bleed down the lifter and give you a false reading).
I am new to efi, and have been racing carb cars for years, so I don't know the relation of kpa to vaccuum, but one thing that I used to do was watch a vaccuum gaugge at wot, if the vaccuum is more than 1.25 inches, then there is a pretty significant restriction in the intake tract. I have also ran 1.625/2.5 headers clear into the 10's and pushing 500 rwhp w/ 2.5" x-pipe exhaust, after switching to 1.75/3.5 w/3" x-pipe exhaust, we saw a gain of 22hp, but the major gains were over 7k rpm. I think your exhaust is fine.
Old Nov 7, 2008 | 03:52 PM
  #79
i dont wanna jack your thread hirdlej, but did anybody clarify if the OS system needed to be changed over from stock, so that we would get the computer to log the higher g/cyl?
Old Nov 7, 2008 | 05:33 PM
  #80
jakebdb56's Avatar
I'm not really sure, but I'll read into it on the HPT forums. I remember reading it somewhere on there or in a book I have.
