my current project
Old May 30, 2007 | 07:04 PM
  #141
Quik's Avatar
5 year bitches!
Originally Posted by 1TRUESS
Quik, what did you do about the throttle cable bracket? Looks like you mounted it different then what I am used to seeing.
for the cable. i took your standard LS1 car cable bracket. and gave it to a buddy. what he did was bent a piece of steel and drilled holes so it would mount to the 2 intake bolts. the placement of the bracket is equal to teh stock placment of a regular intake setup. whats nice is i can still use a microswitch that was designed for mounting on that bracket. then had it powdercoated.
Old May 30, 2007 | 07:23 PM
  #142
1TRUESS's Avatar
Cool. That is what I thought it looked like.
Old Jul 6, 2007 | 01:16 AM
  #143
Quik's Avatar
5 year bitches!
heres some shots of the motor recently at a local car cruise. well since im sure some are wondering how things are going ill tell a few things
i have roughly 1k miles on the setup. first to say 4.88s at 70mph im only 1800 rpms. second i got my emissions done being a full SD truck. 3rd my duty cycle with the svo 42s are around 76%. the sound of the exhaust is a clean loud sound that just gets louder in dbs but doesnt change much at all in sound. truck is very tame up till about 4k. i can load it up in 6th gear at a low mph and around 1k rpms and have no bucking. i got the tune pretty good for driviblity. i dont have any cam surging or bucking, i can almost off idle pull away with this truck. it drives just like a stock motor does down low. it has horrible traction issues tho. i can grab third and have massive wheel hop. i never had issues before but now i do. theres no vibration or anything in the driveline. the air intake is extremely loud in sucking air knowing its a true 4" air intake. motor with the 160 stat and EWP never sees over 180* and soon as it hits that temp it drops down quick. ive had a few encounters with different vehicles on the road and truck just truely surpised me from a roll. ive been up to 130 and that was maxin out 4th gear. it gets up there without any question, it doesnt know its a truck. today i hauled my bike in the back and it didnt even know it was in there. i even had horrible traciton issues merging onto the local parkway. bike is about 400lbs or so in the bed and i still fought traction. rear tires are 305 also.
theres no dyno numbers or track times yet. i just a few hours ago ripped apart my liberty t56. i went to grab third and heard abang and there went the trans. looked underneath when it was loaded up on the tow truck and noticed fluid draining form the tailshaft. i had to undo the driveshaft off the rear inorder for the truck to be towed home. the internals of trans are shot. i can put shifter in a gear and it doesnt matter. truck is stuck in gear and wont move. it didnt move forward or rearward. so now im in hte market for a new trans. besides that issue and traction its been great. exhaust only has a drone around 1200 rpms under load besides that its smooth sounding at cruise speeds. last time i checked im within 1-2% A/F error which makes truck really easy to drive. i got quite a few hours into logging and drivibity tuning.
hope this answers alot of ppls questions. one of the vehicles i had a run in with was a high 11 GN. went from roll about 30 mph i was in 3rd around 2500 rpms or so and i waited from him to build about 4# of boost. it was even till i hit about 6k then i proceded to pull then shfited into 4th and that was the end of that. wondering how i would of done if i was in 2nd and actually in my power range. the range of the cam is from 3500 to 6800.
Old Jul 6, 2007 | 10:45 AM
  #144
Spoolin's Avatar
GFYS and STFU
Awesome write up quik. What kinda of tranny are you gonna be shopping for? I thought T56 were pretty sturdy?
Old Jul 6, 2007 | 10:47 AM
  #145
beastmode's Avatar
Import Moderator
when we racin ***** haha jk bud, that thing looks good... i want a ride
Old Jul 6, 2007 | 11:53 AM
  #146
BADMOFO's Avatar
Cuz I AM a BADMOFO
That really turned out nice
Old Jul 6, 2007 | 12:50 PM
  #147
KevinF56's Avatar
i want it.
Old Jul 6, 2007 | 01:33 PM
  #148
TurboGibbs's Avatar
Cool. I'm tired of these 4.30's. I'll be going to 4.88's soon. If there is any hills on the interstate it is under load (maf @ 80+). Flat ground is ok but there isn't a whole lot of that around here. Yours is clean! Good job!
And good luck on the trans.
Old Jul 6, 2007 | 05:35 PM
  #149
Quik's Avatar
5 year bitches!
i just orderd a D&D viper spec'd T56. yes a t56 can hold 450ftlbs of torque. i had a liberty proshifted one but i guess it wasnt strong enough. so im hoping this one is strong enough and comes with a unlimted mile 6month warrenty
Old Jul 6, 2007 | 05:37 PM
  #150
Quik's Avatar
5 year bitches!
yep dont think twice of the 4.88s. like i said at 1800 rpms at 70mph and i max out 4th gear at 130 but that is also at 7k rpms
