That much loss in power?!?!?!?!?!?
No i could feel a huge difference between my 5.7 and then goin to the 383. But when i was messing with the software it fealt like i had my old 5.7 back in. I went back to the things i had changed and put them back and it literally fealt like i had gained half a second. Also another thing is it seems like it might be slipping on the 1-2, and with logging it is showing about 1500 rpm slip speed around 5000 rpms. The slip seems to be comming from the converter because we locked it up and the sleep speed went to like 100 rpm. I now have it setup to where the torque converter locks in second and when it locks it pushes you back hard... theres a huge difference between it being locked and not locked, it feels like shooting a 50 shot when it locks. For some reason my converter is a little to loose. Also the other thing that is wierd is we did some testing with some of the other tunes i had came up with and there was definately a noticable decrease in power when i changed the settings, but i noticed the changes i made seemed to throw the ve table off because my fuel trims went all wacky. Could that have been what caused my power loss? All i changed was the pe multiplier and pe spark correction and then a few trans tables
Oh ya, another thing. After i loaded the tune that wasn't messed with back in i found a bmw z4 to race with the 2.5, which i beat by about 4 cars and i looked up the stats for those and they are supposed to run a 14.2 stock
Originally Posted by Allgonoshow
I'd get a professional tune....
Ahh I see now you messed with the tune? So you havent been tuning long at all I assume and you probably didnt have much trouble tuning your old motor! It was pretty straight forward. From the sounds of it you need to either get with someone who has tuned a similar motor our get a dynotune. Not that you couldnt do it but from the sounds of it your truck needs some real attention in the tuning area!
Originally Posted by rcfast
Uh, cool.. i wouldn't, i like doing everything myself and want to learn how. I already have a mail order tune as my base tune and the only reason for that is because they didn't make software that could tune my truck until about 3 weeks ago, but you can't get a perfect mail order tune so thats why im trying to tweak it and im learning as i go... But what i changed in theory should have made it faster, but it didn't
Also is your truck NA or SC? You might think about adding more info to your sig.
Ken
