MT -ET streets
The direct link isn't working
www.jegs.com search part # 672-3796 for et streets finally on the web site. <img border="0" alt="[burn out]" title="" src="graemlins/gr_burnout.gif" /> <small>[ March 08, 2003, 08:28 AM: Message edited by: creederado ]</small> |
Re: MT -ET streets
NICE!!! I wish I was fast enough to need A SLICK (still have open dif <img border="0" title="" alt="[Frown]" src="gr_sad.gif" /> lol) Maybe one day I will be faster... anyone wanna donate some money to me?? <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Re: MT -ET streets
i've been waiting for those aren't those still dot aproved because thats what i want
marc |
Re: MT -ET streets
DOT approved, You have to get MT tubes, which cost around 50. Jegs is getting a new shipment march 15,
I only live 1/2 away from the track so throwing them on in my driveway will save the trouble of doing it there. Another option is nitto drags, 305/45-18 ,240 from jegs, no tubes needed. p#726-401888 I'd rather stick with the et's. <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" /> <small>[ March 08, 2003, 11:11 PM: Message edited by: creederado ]</small> |
Re: MT -ET streets
so i have to have tubes to make them street legal cuz i would like these for some street racing
marc |
Re: MT -ET streets
The tubes allow them to work,The tires arn't steel belted and can't support the truck without tubes. The DOT specs here only call for a 2-3/32 tread depth. (That is not alot) The MT's have lines running with the direction of travel which meet the so called Tread depth.
I certianly don't know alot about installation on the rim but I was told you had to run tubes to support the weight of the vehicle and allow the outer tire flex on acleration. Somebody chime in if I'm way off. <small>[ March 09, 2003, 10:05 AM: Message edited by: creederado ]</small> |
Re: MT -ET streets
I have MT ET streets on my ext cab truck and have no problem without tubes. They are 28-15-12.5" I do run them at 20psi, which is where the max load specifications are at. I'm not making that much power, but they hook off the line!!!!! Enough to run 1.9x 60' times.
Re: MT -ET streets
ok so i dont need tubes or what?
marc |
Re: MT -ET streets
im not runnin tubes on mine. those bitches are expensive! lol
Re: MT -ET streets
No tubes here...most of the F-body guys don't run tubes either.
kent |
